boomerangs
rthrbfishn
- My Cars: 1971 GTX
boomerangs
I have found a couple cracks in the plastic callouts on the hood. What is a good repair for these? There are three attaching studs that have twisted out of the plastic that need repair too. Perhaps epoxy some studs in?
- DSC07862.JPG (109.39 KiB) Viewed 9471 times
1971 GTX 440
1967 Barracuda 383 Fmla S
Re: boomerangs
I had some damage to my air grabber door - which I THINK is made of the same material. While they weren't cracks, they were areas where the material has gotten soft and deeply pitted. I used plain old fiberglass epoxy and it seems to have made the repaired areas stronger than the original, and has bonded well.
If it were me - I would put some fiberglass epoxy and matting on the inside first to reinforce the area good. Probably several inches on each side of the cracks. On the outside I would dremel out some narrow channels to widen the cracks and fill with fiberglass epoxy, then sand smooth.
Re: boomerangs
make sure you drill a small hole at the end of the crack too....that will keep it from growing
72Satellite440
Re: boomerangs
JB weld is a great epoxy id try that one first-'
72Satellite440-Dan
72Satellite440-Dan
72-SaTeLliTe440-Dan
rthrbfishn
- My Cars: 1971 GTX
Re: boomerangs
Thanks for the ideas.. I'll let you know how it turns out.
1971 GTX 440
