boomerangs
rthrbfishn
My Cars: 1971 GTX
boomerangs
Post by rthrbfishn » Tue Apr 26, 2011 11:40 pm
I have found a couple cracks in the plastic callouts on the hood. What is a good repair for these? There are three attaching studs that have twisted out of the plastic that need repair too. Perhaps epoxy some studs in?
1971 GTX 440
1967 Barracuda 383 Fmla S
RS23U1E
Re: boomerangs
Post by RS23U1E » Wed Apr 27, 2011 9:16 am
I had some damage to my air grabber door - which I THINK is made of the same material. While they weren't cracks, they were areas where the material has gotten soft and deeply pitted. I used plain old fiberglass epoxy and it seems to have made the repaired areas stronger than the original, and has bonded well.
If it were me - I would put some fiberglass epoxy and matting on the inside first to reinforce the area good. Probably several inches on each side of the cracks. On the outside I would dremel out some narrow channels to widen the cracks and fill with fiberglass epoxy, then sand smooth.
Re: boomerangs
Post by Eric » Wed Apr 27, 2011 12:01 pm
make sure you drill a small hole at the end of the crack too....that will keep it from growing
72Satellite440
Re: boomerangs
Post by 72Satellite440 » Wed Apr 27, 2011 5:26 pm
JB weld is a great epoxy id try that one first-'
72Satellite440-Dan
72-SaTeLliTe440-Dan
rthrbfishn
My Cars: 1971 GTX
Re: boomerangs
Post by rthrbfishn » Thu Apr 28, 2011 9:22 am
Thanks for the ideas.. I'll let you know how it turns out.
1971 GTX 440
