- My Cars: 1971 roadrunner
Post
by mopar71 » Mon Nov 19, 2007 11:25 am
The radiator support number would be the turning point for me!
Mo Power
Post
by Mo Power » Tue Nov 20, 2007 12:19 am
Ok hey sent me these pictures of the torsion bars and looks bad. But I was wondering if someone can help me with exact location and does they sell patchs or overlapping patchs like I've seen on frame rails they sell. And said it's bad only from one side but looks to me as it's from both sides of it.
- 78678.jpg (16.88 KiB) Viewed 19027 times
- 67536.jpg (16.34 KiB) Viewed 19027 times
RM23H2G187947
1972 Dodge Dart Swinger
Post
by CtownRunner » Tue Nov 20, 2007 7:01 am
I used caps for the torsion bar area from Auto Rust Tech. There have the frame rail caps also.
800-407-7024,
www.safetcap.com
Mo Power
Post
by Mo Power » Wed Nov 21, 2007 7:06 pm
Also does yearone sell these rear shock mounts that bolt under rear end? Or any other mopar provider you guys know of?
- REARSHOCK.jpg (18.99 KiB) Viewed 18984 times
RM23H2G187947
Mo Power
Post
by Mo Power » Thu Nov 22, 2007 1:01 pm
So could anybody help me out cause I've looked through yearone catalog and didn't find that bracket.
RM23H2G187947
Post
by 1972RM23 » Fri Nov 23, 2007 10:53 am
Email Jimmy Boros
charger7172@msn.com
He has everything for 1971-72 cars.
Give him a try.
Mo Power
Post
by Mo Power » Fri Dec 28, 2007 12:18 am
I finally purchased this Roadrunner and well this thing it a real Roadrunner. It took me 18 hrs worth to go down and get it and now I'm happy to start doing what can for it to get it to a couple car shows or what not.
RM23H2G187947
moparbrian
Post
by moparbrian » Fri Dec 28, 2007 1:40 am
So in 72 the "G" was for the sunroof and in 73 the sunroof was coded M52.
Post
by Eric » Fri Dec 28, 2007 10:11 am
moparbrian wrote:So in 72 the "G" was for the sunroof and in 73 the sunroof was coded M52.
For some reason, Chrysler didn't code the sunroofs in 71/72 on the fender tags (except in the VON). The correct code for those years is M51, and would have shown on the broadcast sheet. These years had a power sunroof (I believe 72 was still power....someone correct me if I'm wrong here). Later years, 73/74 switched to a manual crank.
Post
by Eric » Fri Dec 28, 2007 10:14 am
Mo Power wrote:I finally purchased this Roadrunner and well this thing it a real Roadrunner. It took me 18 hrs worth to go down and get it and now I'm happy to start doing what can for it to get it to a couple car shows or what not.
Hey Mo
I'd be interested in seeing photos of the fender tag and broadcast sheet
Post
by mopar71 » Fri Dec 28, 2007 12:57 pm
Do you have a pic of the front grill of this car?
Mo Power
Post
by Mo Power » Fri Dec 28, 2007 2:10 pm
Settle down guys I'm just one guy
. But ya I'll post the fendertag along with the fairly decent grill as well. Also I'm going to post some pictures of rust areas that I'm not quite sure what should do. Like to cut out or replace or fill in with MIG.
RM23H2G187947
AZ-Nick
Post
by AZ-Nick » Fri Dec 28, 2007 3:11 pm
Well congrats on the new car, I know there was a lot of controversy on it and all is well because it is real.... Good Luck and please keep us posted on the progress with lots of pictures.... Nick
71 GTX 4sp GY9
70 R/T Challenger - 80's look
Mo Power
Post
by Mo Power » Fri Dec 28, 2007 6:47 pm
Here are my pictures and others to make everyone happy
. And for the floor will I need 3/4 one since its rusted just a little underneath the seat? And is that the cluth hole and where do I get a plug for it? The hinge is getting thin so I though about filling the hole in with mig. Same with the inside by the door sill plate.
- IMG_0704.JPG (23.81 KiB) Viewed 18765 times
- Grill
- IMG_0711.JPG (31.37 KiB) Viewed 18765 times
RM23H2G187947
Mo Power
Post
by Mo Power » Fri Dec 28, 2007 6:48 pm
More
- IMG_0722.JPG (28.69 KiB) Viewed 18764 times
- IMG_0707.JPG (26.38 KiB) Viewed 18764 times
RM23H2G187947
