what is top speed with 391 gears?
- scottish440
I am putting a car together and will be using a 391 posi rear
and a 727 with a built 400 BB
My question is: What will be my top speed in 3rd gear?..
..or my feel like top speed...you know with these big block it
seems like you get to your limit sooner than a small block!!
====,_ '__..........====,_
..............`~. \__./
..........___.--~\./~--.__
- 72GY9Runner
Depends on what your rear tire size will be, and what you want to have for maximum RPM.
My wife's Cuda with 205/70/14's, with a 3.91 diff has been to about 100 mph, but it was screaming pretty hard by then. There's no tach in her car so I'm guessing it was between 5500 and 6000 at that point.
I also know that my Valiant revs about 3300 @ 60-65 mph with the same ratio and tire size as above.
I plan on running the same gears with my Runner, but with a 275/60/15 which should get the top end revs down quite a bit. Not sure what the top end will be yet though.
Dave Lutz
- JosephGiannini
- 72GY9Runner
That's a cool link.
Any idea what ratio the transmission would be? I assumed 1:1 since they aren't overdrive. and got a top speed of 127 mph with my chosen tire size and 3.91's. If I keep my 3.23's, I end up with a top speed of 149mph at 5800 rpm.
And my Cuda on 14's will apparently top out at 119 @ 6000rpm.
Dave Lutz
- JosephGiannini
Actually they make a over/under drive gear vendors or cope racing transmission
and the gear ratios in a 727 are the following
1st 2.45
2nd1.45
3rd 1.00
if memory serves me right
however if you look for acceleration you want a larger gear
3.55,4.10,.4.55,4.75,5.25,5.75
But it wont give you high end top speed it will reduce
The capability to reach top end. However acceleration is vastly improved
With acceleration fuel mileage decrease.
So I like a 2.71 gearing myself
If I could i would get a custom 1.7 or 1.6 myself
http://www.gearvendors.com/
http://www.coperacingtrans.com/odunits.htm
1st 2.45
2nd1.45
3rd 1.00
A Mopar god Is dead.
1972 roadrunner.
1972 roadrunner.
question...i put in the info and used the 1:1 for transmission final ratio and that isn't right at all....i've had my 440 satellite pushin 170 with my buddy in a hopped-up newer trans am behind me...so why does it say 150 something??? does this not consider engine power or does that matter? i said 3.23 rear gears, cuz i think it is still just stock satellite under there
thanks
thanks
- 72GY9Runner
If the car has had a differential gearing change, and the transmission speedometer gear was not changed to match, then the speedometer will read incorrectly. For example, if you changed from a 3.23 ratio to a 3.91 ratio, then your speedometer will show a faster speed than you are actually travelling. In addition to that changes in tire size from factory spec will also affect the reading. If the car is slammed on the ground like you stated, I suspect he is also running a low profile tire. This would drive the speedometer reading even higher.
Just my 2 cents.
Just my 2 cents.
Dave Lutz
- JosephGiannini
to get top speed accurately you can get a radar/laser reading.
or you can do stopwatch mathematics.
http://www.hypertextbook.com/physics/me ... /velocity/
1972 roadrunner.
1972 roadrunner.
Top Speed
Keep in mind that unless you have a lock up torque converter, you're going to lose about 10% of your rpm's to slippage. And at speeds above 110 mph you're going to lose a bunch of power just to fight wind resistance.
I have a 71 Satellite running 370 hp, 410 torque, 3.23's, 245/60-15 tires, and a gear vendors overdrive that gives me a top gear of 0.78. And I think my top speed would be about 150.
- Jim
- Jim
