engine codes
- aerodynamic
engine codes
Hey all,
There's a guy in town with a 72 440 for sale, $300. Are there markings on the block to indicate whether or not it's a HP? What should I look for?
Thx
Thx
73 Road Runner 400 auto
72 440
hi look for a h AND hp on the pad h is a 72 440 AND a 73 440 is J
b-66
C 67
D 68
E 69
F 70
G 71
H 72
J 73
b-66
C 67
D 68
E 69
F 70
G 71
H 72
J 73
- aerodynamic
- scottish440
homing in on a 440
440 blocks are mostly the same(Industrial, Car,or motorhome)...
76 and up have slightly thinner walls
Not all motor homes have the water "jacketed" heads...mostly
they came with standard 440's
I would check to make sure that is is not a 413....same as a 440
but with lesser bore....came in alot of early 70's motor homes.....sounds
better to have a 440....even though you can make a 413 run like stink...
also the transmission guy said that he has seen motor home with
the hemi style trans....these will have the extra wide front band.
good luck and the price sounds right
====,_ '__..........====,_
..............`~. \__./
..........___.--~\./~--.__
- aerodynamic
- aerodynamic
Well, I couldn't find any H's at all on the block. There were some numbers on the side spaced roughly this way:
11 5 76 (sounds like a date to me)
and underneath that:
4006630-440-9
Stamped on top of the engine at the rear and facing up was:
7T4 440 E
All greek to me...any ideas?
4006630-440-9
7T4 440 E
- scottish440
lordy four fourdy
the E is for cast crank...and you are correct that is the date...11-5-76
T is for truck...but I guess the group toghether (7T4) is for motorhome.
SOME 4006630-440 cast in '76 and later have REALLY thick main saddle supports. This would be great for lots of tourque and MONSTER horse power!!!!
By the way did the heads look normal?
- aerodynamic
- scottish440
freak of nature
no you would sure know the "water jacketed" motor home heads...
they are a true freak of nature!!!!
- mopar71
- My Cars: 1971 roadrunner
The motor home heads have a casting number of (3751213).
To Quote Ma Mopar" The 1976,77,78 blocks for the 400 and 440 are thinwall casting design. As such they shouldnt be overboard more than .020" Therefore the pre-1976 blocks are better for racing purposes.
