Post by 71Beeper » Sun May 06, 2018 7:49 pm
So now I'm going back to the front part of the car to where the front torque boxes sit.
I decided to buy a spot sandblaster gun.
The attachment spot blaster. JPG is no longer available
I want clean up the are where the torque box will go as it won't be accessible once the torque box goes in.
So I borrowed my good friends portable air compressor that runs on 110 power and is mobile.
Here's the before pics.
The attachment 20171202_120423.jpg is no longer available
The attachment 20171202_120417.jpg is no longer available
And now after blasting and put some primer on it.
The attachment April 28 (4).jpg is no longer available
April 28 (2).jpg (91.79 KiB) Viewed 28938 times
Post by 71Beeper » Sun May 06, 2018 7:50 pm
A couple more pictures........
The attachment April 28 (5).jpg is no longer available
April 28 (6).jpg (91.08 KiB) Viewed 28938 times
Post by 71Beeper » Sun May 06, 2018 8:16 pm
Looks like my before pictures disappeared. I'll try and post them again.
The attachment 20171201_194832.jpg is no longer available
And heres the picture of the spot blaster I bought.
spot blaster.JPG (29.98 KiB) Viewed 28937 times
Post by 71Beeper » Tue May 15, 2018 8:38 pm
So I got a little more done.
I ended up pitching the little spot blaster. It would not get into the tighter areas very well.
With the reservoir on the top, you couldn't turn the gun at any angle or the sand would stop flowing.
So I went and bought a portable 2.5 gallon kit. This one works much better.
I got the top area done right up to the rear torque box.
Post by 71Beeper » Sun May 20, 2018 8:53 pm
Did some more sandblasting yesterday.......
May 19 (1).jpg (72.82 KiB) Viewed 28890 times
May 19 (3).jpg (81.8 KiB) Viewed 28890 times
May 19 (6).jpg (94.96 KiB) Viewed 28890 times
May 19 (8).jpg (78.18 KiB) Viewed 28890 times
May 19 (9).jpg (112.53 KiB) Viewed 28890 times
Post by 71Beeper » Sun Jun 03, 2018 7:36 pm
Continuing on with blasting. I've stopped using sand - it's too dusty.
I've switched over to recycled glass, a 30 to 60 grit grade. Much less dust. I'm blasting the rear shock mount cross-member.
May 28 (2).jpg (86.67 KiB) Viewed 28842 times
I'm seeing some part number stampings
May 28 (9).jpg (88.67 KiB) Viewed 28842 times
May 28 (13).jpg (79.9 KiB) Viewed 28842 times
Post by 71Beeper » Wed Jul 04, 2018 1:41 pm
Due to the intense heat, the compressor is pushing out air filled with water vapor. That in turn is clogging up the blasting gun.
Also the recycled glass is starting to clump up. With all those issues the blasting has been slow going. But I did manage to get more of it done.
May 28 (7).jpg (67.59 KiB) Viewed 28752 times
Here, I am getting closer to the bottom.
June 24 (10).jpg (120.59 KiB) Viewed 28752 times
I gave the drivers side inner frame rail a blast and put primer on it too.
June 24 (13).jpg (62.87 KiB) Viewed 28752 times
I did manage to get the shock K-member done.
June 24 (20).jpg (64.58 KiB) Viewed 28752 times
June 24 (21).jpg (80.91 KiB) Viewed 28752 times
Hopefully the rest of the underside will be easier.
Post by 71Beeper » Sat Jul 28, 2018 9:47 pm
Made the most progress today.
With the weather being dryer out - I wasn't getting as much water thru the air lines as previously.
Progress went from this.
July 28 (11).jpg (88.99 KiB) Viewed 28716 times
To this.....
July 28 (13).jpg (73.3 KiB) Viewed 28716 times
To all of this....this is all bare steel.
July 28 (24).jpg (98.66 KiB) Viewed 28716 times
And now after a coat of primer added.
July 28 (27).jpg (97.68 KiB) Viewed 28716 times
July 28 (28).jpg (99.55 KiB) Viewed 28716 times
Post by 71Beeper » Sun Aug 26, 2018 8:32 pm
Continuing on with the sandblasting theme, I was able to get more done.
Before shot.
After blasting....
Post by 71Beeper » Mon Sep 03, 2018 7:39 pm
Happy Labor day to all!
I spent my labor day actually doing labor......more sandblasting that is :D
I am starting to see the light at the end of the tunnel.
Before shot..
Sept 3 (3).jpg (67.85 KiB) Viewed 28595 times
After blasting..
Sept 3 (5).jpg (71.56 KiB) Viewed 28595 times
Sept 3 (6).jpg (81.15 KiB) Viewed 28595 times
Just this little area left to do..
Sept 3 (8).jpg (90.98 KiB) Viewed 28595 times
Post by 71Beeper » Wed Oct 10, 2018 7:51 pm
I was finally able to finish up blasting the rest of the underside and getting it primed.
Sept 9 (13).jpg (99.93 KiB) Viewed 28446 times
Now the fit-check for the front torque boxes.
Here's the drivers side.
Sept 9 (18).jpg (82.26 KiB) Viewed 28446 times
And the passenger side.
Sept 9 (24).jpg (64.19 KiB) Viewed 28446 times
Sept 9 (29).jpg (86.45 KiB) Viewed 28446 times
Next is to prep for welding them in......
Post by 71Beeper » Sun Oct 28, 2018 7:39 pm
So after a bit of prep, I got the torque boxes welded in and put some primer on them.
Oct 14 (12).jpg (90.85 KiB) Viewed 28351 times
Oct 14 (13).jpg (52.77 KiB) Viewed 28351 times
Oct 14 (15).jpg (80.88 KiB) Viewed 28351 times
Post by 71Beeper » Sun Oct 28, 2018 7:44 pm
Finally I was able to scuff the whole underside and lay down 2 good coats of epoxy primer sealer.
At least the whole underside is now one color. :D
Oct 28 (7).jpg (113.87 KiB) Viewed 28351 times
Oct 28 (1).jpg (129.18 KiB) Viewed 28351 times
Oct 28 (9).jpg (123.57 KiB) Viewed 28351 times
After this, I'll put two coats of regular primer on top of that and then she can come off the rotisserie!! :beer:
Checking my files - shes been sideways now for 1 full year........sheesh.
Post by 71Beeper » Sun Dec 09, 2018 9:26 pm
Well, I was finally able to get some work done today.
Now that she is all one color underneath.......
Dec 9 (10).jpg (125.62 KiB) Viewed 28050 times
It's time to come off the rotisserie.
Dec 9 (14).jpg (138.27 KiB) Viewed 28050 times
Dec 9 (16).jpg (125.5 KiB) Viewed 28050 times
Dec 9 (18).jpg (128.04 KiB) Viewed 28050 times
Dec 9 (19).jpg (117.64 KiB) Viewed 28050 times
The next step is to clean ALL of the glass bead out of her :shock: before setting her up on jackstands. :D
Post by 71Beeper » Sat Dec 22, 2018 6:07 pm
Because of the sandblasting and crap getting everywhere, the primer in the engine bay has discolored (I didn't cover it up before blasting).
So I scuffed the firewall and inner fenders and rad support & laid down a final coat of primer.
Dec 20 (5).jpg (102.64 KiB) Viewed 27973 times
Dec 20 (6).jpg (104.64 KiB) Viewed 27973 times
Dec 20 (10).jpg (104.66 KiB) Viewed 27973 times
Dec 20 (11).jpg (106.04 KiB) Viewed 27973 times
Dec 20 (8).jpg (88.78 KiB) Viewed 27973 times
