Better than the Chinese Aluminium Garbage on the market these days. Just Sayin!
Aluminum Radiators
Re: Aluminum Radiators
Another option is to have an original Recored about 400.00-500.00
- My Cars: 71 GTX
Perspective on the cost of radiators. I worked for 24 years in the radiator dept. of a tier 1 auto supplier that used to be part of that company with the ford-letter name.
Modern radiators use plastic tanks rather than aluminum tanks, which is a material cost save. There is a gasket between the tank and the core header. The header has tabs which are folded over to compress the tank against the gasket and hold it on.
An aluminum tank could be installed the same way, although I've never seen one. They can be brazed on, or welded on. More costly process.
Our internal cost to produce the biggest, heaviest radiator we made in 2014 (plant closed that year) was about $60. This was medium rate mass production on a line that made about 100 radiators per hour.
These radiators went into new production cars and could be bought at a dealer parts and service dept. for well over $300. How's that for markup?
Aftermarket radiators that are visually an exact reproduction of a Chrysler product would be low-volume production with inherently high cost. But $800. Yow.
- My Cars: 71 roadrunner
I just went with the 4 core aluminum champion rad and its sub par fit, and spray painted black, looks awesome! I think it was like $230 shipped, seemed like a no brainer
