Gas Tank
Re: Gas Tank
It's the exact same one I have in my 71 Charger.. same 4 side vents. CR10A
I'll crawl under my Satellite tonight when I get home.
And a roadrunner clone
Re: Gas Tank
Its correct for a 71 and 72 up to I believe sometime in MArch when the vapor canister got moved to the front of the tank
1971 drag car
1972 440 6pack Roadrunner
1971 drag car
- rr6pak
- My Cars: 1971 Tor-Red RR
Re: Gas Tank
Correct and jsbrown AKA www.521restorations is a good vendor to deal with
- My Cars: 71 GTX
Re: Gas Tank
Looks just like mine as best I can see with it in the car.
Raises a question for me:
How are the filler neck and pickup/sender assemblies attached? I can't see any evidence of screws on mine? Maybe it's in my service manual?
- rr6pak
Re: Gas Tank
The filler neck goes in a large "o-ring" type seal, sender is held in the side with a gasket and large lock ring that holds it in. All should come with a kit, I think. If you have the manual or parts catalog, it's in section 14, fuel. Both have pictures of what I'm talking about71_bronze_gtx wrote:Looks just like mine as best I can see with it in the car.
- My Cars: 71 GTX
Re: Gas Tank
I have both 71 and 72 manuals, and neither one has a decent picture of the filler neck or the sender installations. However, a friend of mine showed me samples of both.
The piece they call a ground clip - this thing appears to make an electrical ground "jumper" around the short section of hose between the fuel line heading to the engine and the tube stub at the tank. I can't spot any ground clip on my tank, but the gauge works.
Re: Gas Tank
You are correct - the jumper is for ground. Scott.
