Manual brakes to Power brakes quesion
mrsnicks
Hey guys. I have a 71 Plymouth SSP with manual brakes. If I want to convert to power brakes to I just need to buy the MC/Booster combo from the big box store? Will the bracket on the firewall work between the 2 or do I need to get a Power bracket?
Thanks,
Patrick
Thanks,
Patrick
moparmarks
Re: Manual brakes to Power brakes quesion
Will need the backing plate for power that goes on the firewall. Also will need the bell crank linkage that goes on the pedal.
Southwestern Sheet Metal
71-4 B-body
71-4 B-body
mrsnicks
It looks like I already have the plate on the engine side of the firewall.
Anyone have one of the brake pedal linkages for sale?
Found this, http://www.ebay.com/itm/331541668819?_t ... EBIDX%3AIT , but don't need both and don't want to spend that much.
Thanks,
Patrick
Thanks,
Patrick
One other thing to keep in mind. After you get every thing installed the pedal will be closer to the floor, about even with the gas pedal.
moparmarks
The manual backing plate is different than the power one.mrsnicks wrote:It looks like I already have the plate on the engine side of the firewall.
Thanks,
Patrick
71-4 B-body
71-4 B-body
mrsnicks
This is the plate on the car. Is it manual or power?
Have you used power brakes on these cars before and liked them? Maybe I'm the only one, but I don't like them.
I have power disks on my Challenger and on my SSP, but I have manual disks on my Duster. I have never liked the feel of the power disks on my Challenger. They work great, but the pedal feel is awful. Same for the SSP, although I have a lot more miles in the Challenger (over 50k now). The manual disks on the Duster require a little bit more leg effort (not a lot), but the pedal feel is much better. The pedal feel on the Duster is crisp and responsive, while the pedal feel on the Challenger and SSP is somewhat more vague. Again the brakes work great, they just don't feel great.
I only mention it because if I do any conversions, it will be to convert my power brake cars to manual brakes, not the other way around. The Challenger will definitely be converted to manual disks. The SSP will probably stay power, but just because its a numbers matching car.
'71 SSP GA4
moparite
I guess you never tried to stop in a hurry when going 100+ with manual drums. It's not easy even with both feet on the pedal! Don't ask how i know this. LOL My Challenger (along with all my other mopars) has power disk's and loved them! No way i would convert to manual.
mrsnicks
Back on track.. Is the booster plate on there now for a manual or a power brake setup? Do I need to purchase a new plate?
Does anyone have the linkage for sale?
Thanks,
Patrick
Thanks,
Patrick
That plate is neither. As in, that's not a stock plate. Your car has been modified, the bolt heads are a dead giveaway. You should either have studs that come through from the pedal mount on the other side of the firewall, or studs on the power booster. You should not have bolts in either case. On top of that, the stock plates have a rounded bend on the edge, it's not just a straight bend like on your plate. Sorry, while I have linkage on my Challenger that eventually I won't be using after I convert to manual disks, it's still on the car at the moment and I'm not ready to do the swap yet.mrsnicks wrote:Back on track.. Is the booster plate on there now for a manual or a power brake setup? Do I need to purchase a new plate?
Thanks,
Patrick
This is what a stock plate should look like...
Power brake plate
Manual brake plate
Guess you're wrong, because I have in fact tried to stop in a hurry with manual drums from 100+. Which is why I never mentioned DRUM brakes in my post. My cars have manual DISKS, which I thought I made pretty clear. Adding a power booster doesn't improve your stopping distance, assuming you're strong enough to actually apply the brakes properly. If everything is sized properly, ie, master cylinder bore, wheel cylinder bores, and piston diameters (for disks), you shouldn't need two feet regardless.moparite wrote:I guess you never tried to stop in a hurry when going 100+ with manual drums. It's not easy even with both feet on the pedal! Don't ask how i know this. LOL My Challenger (along with all my other mopars) has power disk's and loved them! No way i would convert to manual.
Like I said, I have had, and have, both power and manual disks on my cars. The power disks are noticeably worse for braking feel (not stopping distance, that's the same). Yes, the effort is less, but the braking feel is much less precise. Fine I suppose if you're driving miss daisy, not acceptable if you're running autoX or road courses, or simply prefer a more performance based car.
'71 SSP GA4
moparmarks
Classic has the plate and linkage for 100.00. Buy them when they have 25% off for 75.00
71-4 B-body
71-4 B-body
