Roadrunner/Satellite vinyl top
badfast
- My Cars: 1971 Plymouth Satellite Sebring PLus
Does any one know if there is a replacement molding clip for the PN 6003313 for the vinyl top on my 71 SSP?
Re: Roadrunner/Satellite vinyl top
badfast,
Many of us probably won't recognize the part by its part number, including myself. Could you describe which moulding strip you are talking about - or do you have an example picture of the clip you could post. A picture helps immensely. R/T Specialties makes a lot of clips - have you looked there? Good Luck!
steved
i did some searching...
found a listing for a collectors auto supply....
http://www.rearcounter.com/6003313-parts1016627.html
i searched around on their website and couldn't find it...might be worth it to call?
I think I know what you're talking about. As the other member suggested, post a picture to be sure. Might have somebadfast wrote:Does any one know if there is a replacement molding clip for the PN 6003313 for the vinyl top on my 71 SSP?
2Tone72RR
I went hunting for these not too long ago for the full vinyl top trim and belt molding on our 72. If they are the same for your 71 then I think you have the incorrect part number. The Chrysler p/n is 6003133, not 6003313. Here is a pic of the clips:
I purchased the last 10 a nice fellow in Georgia had off Ebay a month or two ago. Still needed a couple so I kept looking. As far as I can find the only place left with these is bradsnosparts.com. The last time I talked with him he still had more than 100 left. I just received my order from him and they look correct to me.
Hope this helps!
Rick
Hope this helps!
Rick
Those are the ones for my car I got. In fact, I have a crap load left over. FYI-You might have to trim those little ears down to fit inside some trim, I did. Other than that, worked as advertised. If I remeber, that's the correct P/N Rick stated. It's hard to compare what the FSM and P/N is when the FSM don't show what the clip looks like. My friends '69, for instance, showed MANY different P/N's that said "clip" but no picture to compare apples to oranges. Also, BE CAREFUL with them. I have a vinyl top on my car and they can be a bugger to get them to get on the rivets for the trim. I almost forgot-on the '71 with the half trim roof, the metal clips I found new at a tool store where I live. They had OE clips, screws, etc, etc, etc, a butt load. Brand new and cheap!2Tone72RR wrote:I went hunting for these not too long ago for the full vinyl top trim and belt molding on our 72. If they are the same for your 71 then I think you have the incorrect part number. The Chrysler p/n is 6003133, not 6003313. Here is a pic of the clips:
Hope this helps!
Rick
jsbrown
- My Cars: 71 GTX (FJ6 440+6 5sp)
71 RoadRunner (EV2 383 AT)
... - Location: Colorado
Probably too late to help those on the thread, but we just had the tooling built to make these again, and the bucket load shows up in about 4-5 weeks. The prototypes worked just fine on my GTX's belt moldings... and allowed me to remove the one thinner charger 6003147 I stuffed in one place in hopes of it doing something.
jsbrown
Just got a large box of these, so if anyone needs them, they're around again!
