need pics of your rear seat belts asap!!!
- My Cars: 71 roadrunner
Installing the rear belts and I may be missing something, The problem Im having is the 2 bolts in the middle for the rear belts. I dont know where the belts go or how the go together. I have 4 belts. One long male buckle end for the middle seat, two belts that are stuck together with a molded piece of plastic (both female buckles) and a short female buckle. Any pics of how they go together and what side they go on (left floor bolt or right floor bolt) would be greatly appreciated! !
Re: need pics of your rear seat belts asap!!!
Sounds like your missing two male ends.
those are the two that are bolted to the side of the car under the sidepanels, I'm trying to figure out the configuration of the middle belts and where they gorradar71 wrote:Sounds like your missing two male ends.
hi on pass side is long female buckle and short male
on the driver side is short female buckle and longfemale buckle
I would agree on the pass side. On the driver side I think you will need two long females (one for the side and one for the short male). To the OP, is that long male adjustable.71440 gtx wrote:hi on pass side is long female buckle and short male
on the driver side is short female buckle and longfemale buckle![]()
rradar71 wrote:I would agree on the pass side. On the driver side I think you will need two long females (one for the side and one for the short male). To the OP, is that long male adjustable.71440 gtx wrote:hi on pass side is long female buckle and short male
That sounds right. Unless you have one very thin person in the middle. Correct me if I'm wrong, but I think the only long male belt would be for the front seat shoulder.
Dagnia-did you get the belts sorted out? Pictures? I'm in the process of putting mine in and some is confusing where they go. '71 with Bucket seats AND "buddy seat"
First picture has 2 sets of buckles/receptacles sewn together. My original ones had these together and on one, had a extra single buckle ALL together in a plastic sleeve . The other one had 2 buckles sewn together and a male as a single ALL together. I think these go on either side of the tranny hump, on the inboard side of my bucket seats.
Second picture not sure where these go.
Third- Rear middle, mounting on the hump for the rear end?
- 20181005_140619.jpg (179.31 KiB) Viewed 28983 times
- 20181007_092735.jpg (128.09 KiB) Viewed 28983 times
- 20181007_092750.jpg (171.39 KiB) Viewed 28983 times
