sorta new
pistol grip
- ct71rr
Bruce, thanks for fixing the photos! The previous owner started to paint the car orange. He got as far as the engine bay and jambs. Also looks like he may have grafted a '72 quarter on the passenger's side. There's lot's of mud around the side marker cutout and looks to be a patch. Thanks for the kind words!!
- ct71rr
Re: sorta new
Well, It's been about 6years and 9months since I updated this post. I finally started tearing into my RR this past month. I also rebuilt my garage which, is still under construction. I will try to keep this post updated with my progress.
[img]http://i259.photobucket.com/albums/hh28 ... 7f7692.jpg[/img
This is where I'm at now. The drivetrain and interior are out. I'm waiting for the front body mounts (on order) for my rotisserie so that I can get the car mounted and cleaned up. It reeks of mouse feces. I'm also hoping a body guy I know will be stopping by this weekend to look at the car. It looks like it was hit on the driver's rear. There is a slight buckle in the trunk pan and the frame rail is slightly puckered on both sides just below the trunk. It doesn't look too bad but, we'll see. I also have to replace/repair both quarters, the driver's side floor pan and some small patches here and there. I have most of the parts I need to replace already.
- ct71rr
Re: sorta new
Got the Bird mounted on the rotisserie:
Re: sorta new
Nice space and tools you should get some great work done
- ct71rr
Re: sorta new
Wow! Over 7 years since I last updated my thread! I guess that’s what happens when life gets in the way of our hobby. I finished up my garage and an addition on my house and a bunch of other stuff. I also started working on my Road Runner:
First order of business, replace the rotted driver’s side frame rail. To do this, I removed the floor boards which were pitted and dented and will be replaced too:
After getting in the frame rail, I started looking at the back driver’s side section of the firewall that needed to be replaced. Originally I was going to patch in a piece to fix the area. Then I decided to remove the cowl for a better look. The cowl was also showing rot. Good thing I did, the top driver’s side of the firewall was toast. Sooo...that came out too:
- F8CA4EE6-17AD-4C1F-9517-6136183D905D.jpeg (321.12 KiB) Viewed 115979 times
- ct71rr
Re: sorta new
I also found some rot in the torsion bar crossmember. I’m in the process of repairing that now:
I was not expecting to find this much rot.
I’m not sure why my images are showing sideways?!
- ct71rr
Re: sorta new
And my completed garage:
Re: sorta new
Awesome space! And it looks like you have a lot of work ahead of you on the RR - damn rust! Looking forward to updates on that well optioned Runner.
- My Cars: 1971 Satellite
Re: sorta new
I see your posts over on for B-bodies only.
Get your head wound taken care of, it looks pretty nasty.....
Keep up the great work!
- ct71rr
Re: sorta new
Thanks for the responses. My head is much better now, thanks
Any Idea why images are posting sideways??
Re: sorta new
I think this forum takes your images and displays them with the long edge on the top and bottom. So, if you take your pictures with your phone in the portrait position (long edges on the sides), then it rotates them so the long edge is on the top and bottom. Just my best guess on what's going on.
