Antifreeze Leak
Howco71
My Cars: 1971 Plymouth Sebring
Antifreeze Leak
Post by Howco71 » Tue Jul 30, 2013 10:43 pm
I'm running a rebuilt 360 in my Satellite. I've a leak out of the adjustment bolt to block, on the power steering pump. When the engine was built, all the bolts were degreased in an acid tank, removing rust and some of the metal composition from the bolt, thus the leak. Anyone resolved this problem? I don't know if sealants will work, and I haven't found a source for new bolts yet. Might try plumbers tape??? Howco71
72 cuda repli-mod
Re: Antifreeze Leak
Post by 71_bronze_gtx » Wed Jul 31, 2013 2:15 pm
Maybe drain the coolant, clean out the threads, and apply a fairly liberal amount of blue Loctite.
JimT1971RR
My Cars: 1971 Roadrunner.
Re: Antifreeze Leak
Post by JimT1971RR » Thu Aug 01, 2013 12:19 am
Any time you have a thread to thread connection that doesn't have a compression fitting, with a liquid source being sealed, you need to use some type of sealant. You should be able to use regular teflon tape to seal this connection. I found out the hard way that all the exhaust manifold bolts go into the water jacket and had to teflon tape all of the bolts.
P.S. "plumber's tape", is the metal stuff with the screw holes in it for tying down pipes and stuff.
Jim
moparite
Re: Antifreeze Leak
Post by moparite » Thu Aug 01, 2013 8:02 am
Teflon tape is for pipe threads. Use a good silicone just make sure everything is clean and dry.
Howco71
Re: Antifreeze Leak
Post by Howco71 » Thu Aug 01, 2013 3:09 pm
Will give the sealant a try when I get the car home. It's in the exhaust shop now for some repair. The previous owner used a big hammer to get the exhaust to fit. Some areas of distorted pipe rubbing on the torsion bar and frame. Howco71 (I have a roll of white thread tape. Will try that if sealant doesn't work).
