hey guys, before i had my car painted, my gas needle was working fine. now after the paint job, the oil meter above it is working fine, but the gas needle isnt. i filled up thinking i was on E, but no. can there be a wire maybe the painter removed or messed up bc i see a wire in the middle of the trunk floor thats cut. im wondering if thats the pronblem
can anybody help me with this
gas needle not working
Re: gas needle not working
Would that wire be blue and the other end goes through to fuel tank?
Uppy
- My Cars: Present: 1971 Plymouth GTX
Past: 1970 Dodge Coronet 500
1973 Dodge Charger SE
Check the ground and lead wire from fuel tank. One of them is probably disconnected.
Yep, there is a wire that goes through the trunk floor that is usually blue like rradar71 said. That wire goes to the sending unit on your gas tank. If it is cut, that is why your gas needle does not work. Scott.
esa712
- My Cars: 1972 roadrunner b body
the wire is now a gold colored wire now!!sdweatherman wrote:Yep, there is a wire that goes through the trunk floor that is usually blue like rradar71 said. That wire goes to the sending unit on your gas tank. If it is cut, that is why your gas needle does not work. Scott.
it sits directly in the middle of the trunkl. can that be it?
Uppy
Check to see if this ground strap in on the fuel line at the tank. This ground makes contact with the fuel tank and the metal gas line, bypassing the rubber connecting hose. If this is missing, gage no worky.
- gastankground.jpg (9.76 KiB) Viewed 13631 times
Yes, the wire that goes down through the bottom of the trunk floor is the wire that goes to the sending unit on the gas tank. Like Uppy says - make sure the ground strap is also installed correctly. The strap completes the electrical circuit for the sending unit. Scott.
