canister
roelbest
all matching
canister
Post by roelbest » Sat Aug 18, 2012 9:10 am
Anybody tell me what this is for? It was in line with the fuel line between pump and carb.
Thanks!
Re: canister
Post by 71bird » Sat Aug 18, 2012 9:45 am
Vapor separator. The cars that had that didn't have a filter.I think.
EL5beepbeep
My Cars: 71 Roadrunner - EL5 383 AG
Re: canister
Post by EL5beepbeep » Sat Aug 18, 2012 10:20 am
That is the vapor separator. It is used in place of the fuel filter. It has a filter screen in it. You should also have a 1/4" hard steel return line that goes back to the tank. The smaller nipple on the bottom near the outside rim is the return line. A small piece of 1/4" rubber line should go from that to the 1/4" steel hard line. Your sending unit at the tank should also have a 1/4" nipple for the hard line to connect to.
They were stock on 440 HP, 440+6, and 426 equipped cars from 71 on.
With todays crap gas they actually help a great deal with vapor lock.
roelbest
all matching
Re: canister
Post by roelbest » Sat Aug 18, 2012 12:55 pm
Thanks, there is a 1/4 steel hard line coming from the tank foreward.
When I got the car way back it had an electric Holley feulpump, but I am getting all back to original. Does that mean I do not have to put a fuel filter in? Obviously this cannister is from '72.
Any guess to where it bolt on to the engine with that bracket?
Appreciate the help
Moparlar
And a roadrunner clone
Re: canister
Post by Moparlar » Sat Aug 18, 2012 1:51 pm
It bolts on with the fuel pump, if you don't run the return style filter you do need a regular filter
1971 drag car
1972 440 6pack Roadrunner
roelbest
all matching
Re: canister
Post by roelbest » Sat Aug 18, 2012 3:32 pm
thanks, appreciate the help
