4 vents on gas tank.
E86 GTX
My Cars: 1971 440 GTX Tor Red getting TLC in my home shop...
1972 Satellite parts car
383 Roadrunner back in the late 70's
Post by E86 GTX » Sat May 19, 2012 11:09 pm
OK do I need to hook the 4 vents up on the new tank or plug them. Not making a show car. The tank was removed when I got the car. The new sending unit has a vent or return line also(which one?). The metal line for that is there but I have no Idea what to hook it to up in the engine bay.
..........Thanks: Your Friend Ben
Re: 4 vents on gas tank.
Post by 72RoadRunnerGTX » Sun May 20, 2012 10:15 am
What year car are you working with? Where on the tank are the nipples located? The extra fitting on the sender is for a return line if the car was so equipped.
After a quick post search, appears you are working with a 71’. If the tank vapor separator is present, hook the vent lines back-up to it. Check all hoses for deterioration, replace as necessary. Nothing wrong with the tank vent system as originally designed.
Larger version
Post by 471Magnum » Sun May 20, 2012 4:06 pm
72RoadRunnerGTX wrote:Nothing wrong with the tank vent system as originally designed.
Except that the separator tanks tend to rust out. Give it a close inspection. Have to remove the wheel and panel inside the wheel well to get to it.
I agree with using it if everything is in usable condition. Keeps the garage smelling better if nothing else.
If you plug everything off, make sure you utilize a vented gas cap.
Post by 72RoadRunnerGTX » Sun May 20, 2012 7:23 pm
471Magnum wrote: Except that the separator tanks tend to rust out.
Agreed, like the other tank system components rust can be an issue. There isn’t one part on these cars that was designed with the intention of lasting anywhere near 40+ years however.
E86 GTX
Post by E86 GTX » Sun May 20, 2012 8:31 pm
Thanks for the help guys. The return line. It seems like there was three lines on the fuel pump on my 71 road runner that I sold in the mid-late 70's. was one a return? The pump on this 71 440 GTX has only two lines. In from tank and out to carburetor. There is also a canister under the drivers side front fender that is not hooked up to anything. It has a line that runs up close to the brake booster then ends. The vents in the tank are like the picture you posted, thanks for that. There is another line that runs alongside the gas and return line. It also ends in the engine bay hooked to nothing.
Post by 471Magnum » Sun May 20, 2012 8:38 pm
440 and Hemi cars had a vapor separator fuel filter, which included a 1/4" return back to the fuel tank pick-up/sending unit.
The third line comes off the liquid/vapor separator at the rear of the car and goes to the valve cover breather cap on a 71. On a 72 it goes to the charcoal filter. 1970 N97 (CA emissions) cars also had this feature.
E86 GTX
Post by E86 GTX » Sun May 20, 2012 8:54 pm
OK Thanks Jim. That covers the third line. There is a nipple on the valve cover breather cap that has nothing hooked to it. I will check out the separator because there is a hole in the trunk pan I need to repair right over where the 4 rubber lines leave the tank. I am a retired Boilermaker certified pressure welder, but this is new ground for me. Got some .023 hard wire and bi mix gas. Tried the welder out yesterday on a piece of scrap from the old roof. Welds real sweet. I will just take my time. Got more time than money.
. Thanks Again
Post by 72RoadRunnerGTX » Sun May 20, 2012 8:56 pm
For 71'
E86 GTX
Post by E86 GTX » Sun May 20, 2012 10:59 pm
From looking at the "fuel vapor saver" image you posted it looks like the lines can have no real order in hooking up but I will be sure to hook the line to the valve cover breather back as it originally was.
I went and took the separator off and though it is uglier than a 58 Chevy, it does not seem to have been compromised by the rust. I may coat it with Ospho before I re install it? ? ? When you turn it from end to end I hear one little something fall. Where do you get the fuel filter with the return line on it or do I need it?
> Thanks A Million: Your Friend Ben
E86 GTX
Post by E86 GTX » Sun May 20, 2012 11:01 pm
seperator
Post by 72RoadRunnerGTX » Sun May 20, 2012 11:17 pm
E86 GTX
Post by E86 GTX » Sun May 20, 2012 11:24 pm
WOW! Do I need it that Bad? If it is beneficial I will get one. Maybe not that one.
Thanks:Your Friend Ben
Does it help with vapor lock in hot weather?
E86 GTX
Post by E86 GTX » Mon May 21, 2012 12:19 am
.Or I could stick my foot in my mouth and buy that one. That is the least expensive one
My Cars: 71 roadrunner
Post by dangina » Mon May 21, 2012 2:32 am
I was curious bout this as well do we really need it? or can we get a vented gas cap like someone mentioned earlier (anything to save weight lol)
Post by 471Magnum » Mon May 21, 2012 7:20 am
E86 GTX wrote:WOW! Do I need it that Bad? If it is beneficial I will get one. Maybe not that one.
There is a aftermarket filter out there that will work just as well. The vapor port is on in the opposite side, and it won't have the mounting tab.
Napa FIL3041.
