Rad overflow bottle
roelbest
all matching
Rad overflow bottle
Post by roelbest » Sat Apr 21, 2012 1:59 pm
Does anyone do aftermarket for a '72 Roadrunner? Both my bottles are good, but very stained etc. I guess the yellow label would not be reproduced at all?
rr 129.jpg (123.9 KiB) Viewed 29666 times
rr 141.jpg (125.92 KiB) Viewed 29666 times
Moparlar
And a roadrunner clone
Re: Rad overflow bottle
Post by Moparlar » Sat Apr 21, 2012 2:45 pm
I think Jimmy Boros has new decals.
Larry
1971 drag car
1972 440 6pack Roadrunner
71ChallengerSE
1971 Dodge Demon 'Sizzler'
Post by 71ChallengerSE » Sat Apr 21, 2012 11:25 pm
Good I was wondering about that decal. A previous owner ruined it with paint.
71ChallengerSE
Post by 71ChallengerSE » Sat Apr 21, 2012 11:27 pm
Also both bottles are reproduced, even the one for the heavy duty cooling.
Moparlar
Post by Moparlar » Sat Apr 21, 2012 11:37 pm
71ChallengerSE wrote:Also both bottles are reproduced, even the one for the heavy duty cooling.
I didn't know there were 2 different bottles for 72 . I have only seen 1 style.
Larry
1971 drag car
71ChallengerSE
Post by 71ChallengerSE » Sun Apr 22, 2012 12:30 am
Here is mine, factory HD cooling 72 RR. My friend said that they didn't reproduce these so I looked it up before I took it out in case it broke and I found a repro but it was pricey!
Moparlar
Post by Moparlar » Sun Apr 22, 2012 12:34 am
Does the Repo have the metal bracket riveted to it?
Larry
1971 drag car
roelbest
all matching
Post by roelbest » Sun Apr 22, 2012 5:45 am
Thanks guys, I have sent an email to Jimmy.
YearO does not have the rad bottles, any idea where I can get repo's?
My car also have the HD coolant recovery system
thanks!
71ChallengerSE
Post by 71ChallengerSE » Sun Apr 22, 2012 2:04 pm
Moparlar wrote:Does the Repo have the metal bracket riveted to it?
Larry
Yes the repro had the bracket riveted to it and the other bracket that it bolts to. I only found 1 place that had the correct style, but I can't remember who had it. I'm still looking.
Post by 72RoadRunnerGTX » Sun Apr 22, 2012 2:13 pm
Never found that particular bottle being reproduced anywhere, and I have searched for some time. Bottle and bracket pictured above I believe to be one year only and pretty scarce, couldn’t find a decent used one as well for a reasonable price, the ones I did find looked like crap. I’m running the more common reproduction available; it does fit but is not correct for 72’. I believe it is a later bracket and bottle design with the bracket mounting under the driver’s side radiator bolts.
gary
Post by gary » Sun Apr 22, 2012 10:39 pm
I too am wanting to install a overflow bottle.It's rare to see one on a '71. I have a mitchell's part number service guide that lists two Diff.numbers for '71&'72.I have the repo W/the green cap that i need a mounting bracket for.What year did Chrysler start using the green cap?
:help:
Post by 71bird » Mon Apr 23, 2012 6:36 am
Could you get this on a 71 with Hemi and 26 inch rad with power steering?
Post by 72RoadRunnerGTX » Mon Apr 23, 2012 10:31 am
71bird wrote:Could you get this on a 71 with Hemi and 26 inch rad with power steering?
Will the reproduction bottle & bracket I’m running fit the 71’? Yes, don’t see why not, space and rad mount is the same. Could you get it on a 71' Hemi originally? No.
Currently running Ebay auction for the repo 73-74" E-body bottle.
roelbest
all matching
Post by roelbest » Mon Apr 23, 2012 3:49 pm
Well Jimmy Boros replied very quickly and I have a decal on its way!!
I guess I am going to try and clean my bottles, they have no cracks, are just stained and yellow. Perhaps leave them in bleach for a few days and see how they clean up.
Moparlar
Post by Moparlar » Mon Apr 23, 2012 3:55 pm
Is anyone running the different radiator cap on their Coolant recovery system?
LArry
1971 drag car
