So what do you guys do about your rear swaybars?
71ChallengerSE
1971 Dodge Demon 'Sizzler'
Post by 71ChallengerSE » Tue Jan 31, 2012 2:47 pm
You cant get new endlinks for them and you can't get the brackets either. Do you just throw the factory bar away and go aftermarket?
farmboy70
Re: So what do you guys do about your rear swaybars?
Post by farmboy70 » Wed Feb 01, 2012 12:03 am
The end links are repoped, the brackets show up once in a while on E-bay and swap meets.
BigBlock
(Satellite Sebring Plus)
Post by BigBlock » Wed Feb 01, 2012 2:31 pm
I have only ever seen the ones from PST.
farmboy70
Post by farmboy70 » Wed Feb 01, 2012 8:06 pm
Here is a link showing them. This is not where I personally would buy them but it shows they are being produced.
If I remember correctly the links are the same as 1969 B or A body fronts, not sure on that though.
http://www.jimsautoparts.com/suspension.htm
71ChallengerSE
Post by 71ChallengerSE » Wed Feb 01, 2012 9:37 pm
farmboy70 wrote:Here is a link showing them. This is not where I personally would buy them but it shows they are being produced.
Hey Dave, I took a look at the link and they dont sell anything close to the endlinks for a 72 rear swaybar.
farmboy70
Post by farmboy70 » Wed Feb 01, 2012 10:35 pm
Do you have a picture of your old ones?
farmboy70
Post by farmboy70 » Wed Feb 01, 2012 10:38 pm
Are these what you are looking for?Image
71ChallengerSE
Post by 71ChallengerSE » Thu Feb 02, 2012 12:02 am
These are the ones that i'm looking for or something that will work.
Post by 72RoadRunnerGTX » Thu Feb 02, 2012 12:03 am
May not have the exact same stand-off length but will work on that rear bar in a pinch.
http://www.ebay.com/itm/68-69-70-71-72- ... 35adc08f8f
Chrysler had repair kits similar to this aftermarket one back in the day.
farmboy70
Post by farmboy70 » Thu Feb 02, 2012 12:24 am
OK now I see what you are looking for, the only 72 Body I have worked on did not have that style bar and link arrangement.
E86 GTX
My Cars: 1971 440 GTX Tor Red getting TLC in my home shop...
1972 Satellite parts car
383 Roadrunner back in the late 70's
Post by E86 GTX » Fri Apr 13, 2012 10:54 pm
Does anyone have a photo of how the bar is bolted to the rear end. Will a bar off of a 72 RR fit on a 71 GTX
8 3/4 ? The GTX was born without one, but I hear it makes it a much better handling ride. Worth the trouble or not? Not building a show car. Just want a nice looking(and fun to drive) driver.
................Thanks: Your Friend Ben
Have not been a member of the nest very long, but this is an awesome site.
Post by 71bird » Sat Apr 14, 2012 8:29 am
Go to the mop arts forum and look under the cornering section
Post by 72RoadRunnerGTX » Sat Apr 14, 2012 11:46 am
“Will a bar off of a 72 RR fit on a 71 GTX 8 3/4?”
Yes, all the original 72’ rear anti-sway bar components for the 8 ¾” diff. will bolt directly on the 71’, screw holes in the frame rails should already be there. Rear bars from 73’ and up b-bodies can fit as well however there are some variations in the dimensions of some of the mounting hardware.
“Worth the trouble or not?”
Definitely worth the effort and expense done correctly.
My Cars: 71 roadrunner
Post by dangina » Mon Apr 16, 2012 1:58 pm
Post by rr6pak » Mon Apr 16, 2012 11:24 pm
dangina wrote:I'm going Hellwig front and rear: best deals I found for our cars:
http://www.sdtrucksprings.com/index.php ... s_id=16954
http://www.sdtrucksprings.com/index.php ... s_id=10105
Dagina:
Let us know how they fit and post pix if ou can. I'm interested in those, or others. If not, might just go to FirmFeel route.
72RoadrunnerGTX- I didnt know you bolted yours in, thought those were welded in. Also, are those replacements or orginal? If replaced, where did you purchase them from?
