window help
71runnerm51
window help
opened my door and this fell out, where does it go
- window1.jpg (67.31 KiB) Viewed 10354 times
Re: window help
One of four fasteners that secure the glass to lower regulator track. Likely a screw and a rubber washer or two floating around in there too.
71runnerm51
Re: window help
that's not all that came off the rear track tee bolt ,nut and washer gone also. the tee bolt probably in their to...... going to need to get the door panel off, the remote mirror is a pita
71runnerm51
Re: window help
got the door panel off..and found this laying in the bottom anybody know where I can get a replacement
- bumper.jpg (122.61 KiB) Viewed 10312 times
Re: window help
Since all it does is stop the window glass - and doesn't really take a lot of abuse, I don't think you need to replace it. I see the tab is busted off, but If it were me, I would just use weather strip adhesive and just stick it back in place! Too many other parts you need to spend $$ on. This one could be salvaged.
Re: window help
I might have a good used one laying around for cheap. Let me know if you are interested. Scott.
