Operation 410
Operation 410
Post by 471Magnum » Sun Mar 13, 2011 7:06 pm
Guess what I'm working on... :D
Re: Operation 410
Post by CtownRunner » Sun Mar 13, 2011 7:28 pm
I see a SB stroker in the future.
Your friend has a nice stable of RR's.
beepbeepTyler
Re: Operation 410
Post by beepbeepTyler » Thu Mar 17, 2011 9:26 am
Thumbs up for strokers! Im currently working on an extra 340 I have in my garage. Bored .030" over. Adding 4.00 Forged Crank, Forged pistions, ect. Upping to from 340c.i. to 416c.i. extimated 492hp. :)
big message post signatchahhh.JPG (36.88 KiB) Viewed 22626 times
______
-Tyler
Re: Operation 410
Post by 471Magnum » Thu Mar 17, 2011 1:38 pm
I hope to have the block back for dry assembly in a couple of weeks.
Diriccatiticka
Re: Operation 410
Post by Diriccatiticka » Sun Mar 20, 2011 4:28 pm
I always liked my big blocks, but having a small block screamer...It's hard to compete with that. Way cool man! :D
'72 Road Runner
Re: Operation 410
Post by 471Magnum » Sun Mar 27, 2011 5:30 pm
Got the block back from the machine shop for mock-up. It'll go back this week or next for decking as well as balancing of the rotation assembly.
Cash-flow permitting, I should be assembling the short block within a couple of weeks and maybe even installing it before the end of April.
Re: Operation 410
Post by 471Magnum » Mon Apr 25, 2011 12:51 pm
PROGRESS
Re: Operation 410
ONE MORE
Re: Operation 410
Post by 471Magnum » Sat May 14, 2011 7:46 pm
And now... out with the old...
Re: Operation 410... in with the new
Post by 471Magnum » Sun Jun 05, 2011 10:48 pm
getting closer
Re: Operation 410
Post by 471Magnum » Tue Jun 21, 2011 11:37 pm
Gonna let it rip tomorrow night.
Re: Operation 410
Post by CtownRunner » Wed Jun 22, 2011 2:26 pm
Great, hope is runs as good as it looks.
Re: Operation 410
Post by 471Magnum » Wed Jun 22, 2011 11:02 pm
It is ALIVE!!!!!! :D
After an oil spill and major scare, we got the motor fired and cam broke in tonight.
Blew out the gasket on the filter adapter which dumped about four quarts of oil and dropped the pressure to zero for a few seconds before I got it shut down. Fortunately, no apparent damage and the break-in went fine after the clean-up.
Actually moved under its own power for the first time in over a month. Just a few feet back into the garage though.
Tomorrow night I'll install the inner valve springs. Probably be Friday (weather permitting) before I can flog it.
Re: Operation 410
Post by 471Magnum » Sat Jun 25, 2011 5:26 pm
Nothing to see here folks. Just a stock low compression 72 spec 340. :D
just a stock 340... right
So today I fired it up after installing the inner springs. Started misfiring. Found a loose plug wire. Also found a vacuum leak at the carb base. Got those two issues resolve and took it for a test drive. Runs great. Leaned on it a bit and it started to ping some. Might be due to the 89 octane I used at last fill-up. Need to dial in the ignition curve and total timing a bit better too. I had it pretty aggressive with the low compression motor.
Anyway, thanks to some help from a buddy, we got it running and cleaned up just in time to hit the big cruise-in tonight... then it started to rain. :cry:
all dressed up with no place to go
SureGrip
Re: Operation 410
Post by SureGrip » Sat Jul 02, 2011 7:58 pm
Holy, Close-Quarters, Batman!! :shock:
I need to start researching my 440 stroker buildup. :D
