Differential GEAR Ratios!!
beepbeepTyler
Post by beepbeepTyler » Wed Mar 02, 2011 2:13 pm
Anyone have ideas on a nice gear ratio for a 72' Roadrunner 340c.i. 4-Barrel 727 Automatic? Right now I have 2.76 Highway gears. Although, they are nice and save on gas, I would like to be able to "take-off" the line faster rather than building up my acceleration slowly. I was thinking along the lines of a lower ratio such as 3.55 or lower.
_________
-Tyler
big message post signatchahhh.JPG (36.88 KiB) Viewed 35122 times
______
-Tyler
Re: Differential GEAR Ratios!!
Post by sdweatherman » Wed Mar 02, 2011 3:11 pm
Nice ride and welcome to the nest! I think 3.23s would be the next step up - still good gas mileage but a little better take off. The 3.55s I think would be a good compromise between mileage and acceleration. You running the standard 8 3/4?
Post by bruce » Wed Mar 02, 2011 3:58 pm
I have some 3.55 sure-grip gears I'll trade you for a 3.23 sure-grip! :D
beepbeepTyler
Post by beepbeepTyler » Thu Mar 03, 2011 12:27 pm
I wish I had either one :wink:
______
-Tyler
RS23U1E
Post by RS23U1E » Thu Mar 03, 2011 3:19 pm
I had 3.23s in mine (When the powerplant was a mild 383) and 727. I upgraded those to 3.91s. Lots more oomph, but winds a little bit to high to make it a real long-tripper.
There are some gear ratio / rpm calculators out there. That way you can get an idea of how many RPMs you'll be turning at cruising speed.
http://www.csgnetwork.com/multirpmcalc.html
beepbeepTyler
Post by beepbeepTyler » Fri Mar 04, 2011 7:58 am
Great link. This will help alot!
______
-Tyler
Elvad
Post by Elvad » Fri Mar 04, 2011 10:47 pm
You can also change first gear in the transmission by installing a four gear planetary set found in most motorhome trannys.
beepbeepTyler
Post by beepbeepTyler » Sat Mar 05, 2011 12:39 pm
Thanks for the reply. Im looking for a planetary system right now. haha
______
-Tyler
JosephGiannini
Post by JosephGiannini » Fri Mar 11, 2011 10:32 am
To correctly do a drivetrain for performance. You should profile it from the flywheel back.
There are several ways to improve take off time.
Suspension
Transmission
Differential
Remember if you increase the ratio ie 2.76 2.71 2.79 to a 3.23 3.55 etc
the higher the number the higher the rpm will need to be to sustain speed if you are looking to spin tires
then a higher ratio usually for quarter mile launching however if you contact a drivetrain specialist they do
lower ratio sure grip systems ie 2.7 etc etc ford 9 inches will bolt up and they come in those ratios for the
budget minded builder or you can contract strange or dts and they will make you a dana with sure grip and
ratio of your choice for about 2 thousand dollars but i would choose a mid range ratio and go with a 6 speed
transmission
A Mopar god Is dead.
1972 roadrunner.
beep beep guy
My Cars: 1974 roadrunner clone
Post by beep beep guy » Mon Mar 28, 2011 9:07 pm
bruce wrote:I have some 3.55 sure-grip gears I'll trade you for a 3.23 sure-grip! :D
i have 391 gear id trade you
Mopar or no car! Beep beep
Post by bruce » Tue Mar 29, 2011 9:03 am
I'm looking to go lower (numerically) not higher! The engine in my car is screamin' when I take it out on the highway...
beepbeepTyler
Post by beepbeepTyler » Tue Mar 29, 2011 5:29 pm
Guess I won't be looking for 3.55's haha. Wouldn't want to beat my engine too bad =) 3.23's sound solid to me :beer:
______
-Tyler
Post by Eric » Tue Mar 29, 2011 6:55 pm
If you think 3.55s are rough on the highway, try the 4.10s that came with the super track pack! DAMHIK
Post by bruce » Tue Mar 29, 2011 9:33 pm
beepbeepTyler wrote:Guess I won't be looking for 3.55's haha. Wouldn't want to beat my engine too bad =) 3.23's sound solid to me :beer:
Depends on your combo too--mine is a 451 6bbl with reworked heads and a healthy cam. It's gonna turn different revs than your 318... just a bit of difference. :D
beepbeepTyler
Post by beepbeepTyler » Sun May 22, 2011 8:59 pm
Bruce, Im sure it will :D hahah
and its a 340 (in process of being a 416 stroker) :) Don't low ball me haha :beer:
______
-Tyler
