when i replaced the tank years ago, i just reconnected the 4 rubber hoses that were on the original tank. they run up into an area between the trunk and wheelhouse...don't know after that. the only reason i'm asking is that i'm trying to find a way to run a vapor separator style fuel filter and run a vapor return line back to the tank.
having some trouble with vapor lock, i think. already have a 1" carb spacer and was considering an aluminum heat shield to add to that. i've also considered switching to an electric fuel pump, but not sure that that would solve my problems either.
