1972 Road Runner/GTX restoration
Re: 1972 Road Runner/GTX restoration
Post by 72RoadRunnerGTX » Sat Feb 06, 2010 3:49 pm
Last edited by 72RoadRunnerGTX on Sun Apr 10, 2022 11:18 pm, edited 9 times in total.
pats71
Re: 72’ Road Runner/GTX restoration *Appearance Update*
Post by pats71 » Sat Feb 06, 2010 11:57 pm
I just saw this thread for the first time and listen to your video of your engine running. What size cam are you running in that 440?
1971 Plymouth Roadrunner
383/4 speed/Air Conditioning
Post by 72RoadRunnerGTX » Sun Feb 07, 2010 1:30 am
It's a Mopar Performance P4529270 "Resto" 69-71' 440 Six Pack three bolt re-issue. 268/284 .450/.458 lift. Basically the same grind used originally on all HP big blocks around that time.
Last edited by 72RoadRunnerGTX on Tue Aug 02, 2011 1:07 am, edited 1 time in total.
pats71
Post by pats71 » Sun Feb 07, 2010 1:46 am
Wow that actually sounds really good. I plan on going with a MP .474 grind and thought it might be a tad quite in my HP383. I'm guessing that yours sounds good cause of the headers. What size exhaust and mufflers are you using? Do you like the performance of the cam so far? And how hard is it to tune a six pack setup? My old man is telling me not to do the six pack setup because its hard to tune and work with as far as reliability.
Post by 72RoadRunnerGTX » Sun Feb 07, 2010 3:29 pm
TTI headers (2" primaries) into their 3" x-pipes and Dynomax Super Turbo mufflers. Sounds a bit different from that video with the tips on it now.
How do I like the cam? Love it, 19+Hgs of vacuum at idle, very streetable and goes like a bat out of hell.
Hard to tune a six-pack? No, with basic carburetor knowledge it's just like tuning three separate Holley's, they just happen to be on the same motor. There are a few specific tuning issues associated with the set-up, plenty of info available on-line here and elsewhere.
For us old school motor heads, nothing is cooler to look at. Ok, maybe two AFBs sitting on top of a Hemi.
Last edited by 72RoadRunnerGTX on Sun Apr 10, 2022 11:43 pm, edited 8 times in total.
Post by 72RoadRunnerGTX » Mon Jun 07, 2010 2:36 pm
Another first for my restored car, I backed it out of the garage early Sunday into a wet and rainy day. First time I've used the windshield wipers for their intended purpose since the restoration and so far no water has been found where it shouldn't be. Finally over my water phobia.
Proceeded to drive it to the 2010 Seattle Mopars Unlimited All Mopar Spring Round-Up (CarDomain's coverage). It rained all morning, let up late morning and dried out a bit then started up again late afternoon. Turn out was down for sure this year however a lot more newer cars there this year, including more new Challengers in one place than I have seen to date. Only one other car in my class showed up, pretty original 73' Satellite Custom Station Wagon.
8/1/2010, First time the car has placed at a general all make classic car show since I started showing it, "2010 Shoreline Classic Car Show", winner "Best in Class" (best Mopar). About a mile from home, 225+ cars of all types.
8/22/2010 "Sunbust 2010" Graham,WA
And for the you 73-74' nesters, two of them are original "U" coded RR/GTXs
9/12/2010 "Edmonds Classic Car Show 2010" Edmonds, Washington 2nd place, "Favorite Mopar"
9/11/2011 "Edmonds Classic Car 2011" Edmonds, Washington 1st place, "Fravorite Mopar"
Last edited by 72RoadRunnerGTX on Sun Apr 10, 2022 11:40 pm, edited 15 times in total.
72 U Boat
My Cars: 1972 RR/GTX, 1972 SSP 400 4-Barrel
Post by 72 U Boat » Tue Mar 15, 2011 2:14 pm
Doug,Great Resto-mod! What kind of sub-frame connectors did you use? I plan on using sub-frame connectors in my project and I like the fact that you didn't have to cut through the floor pan to install these.
72 U Boat
Well, I don't know if your like me, but I know I am!
67 Belvedere 1, 440/727 05 Jeep Wrangler 99 Ram 4X4 Cummins
72 RR/GTX, 440/727 08 Mazdaspeed3
72 SSP, 400/727 96 CBR 1000F
I definitely need more space!
beepbeepTyler
Post by beepbeepTyler » Tue Apr 19, 2011 8:14 am
Speechless...WOW! Thats a great RR! :beer:
big message post signatchahhh.JPG (36.88 KiB) Viewed 49186 times
______
-Tyler
Post by 72RoadRunnerGTX » Tue Apr 19, 2011 11:18 am
Thanks, currently changing up the brakes on the car, reworking the rears to allow for the originally planned rallye wheels and upgrading the rotors on the front to the unicast 11.75" rotor. Awaiting the new Wilwood calipers for the 1" thick rotors. Stand by for another "appearance update" shortly.
Front calipers are here finally
Last edited by 72RoadRunnerGTX on Sun Apr 10, 2022 11:46 pm, edited 4 times in total.
Re: 1972 Road Runner/GTX restoration(another appearance upda
Post by 72RoadRunnerGTX » Sat Apr 30, 2011 10:36 pm
Back on the road again after three months downtime changing around a few things.
Now with the "brushed" trim rings and a change in front tire size from 235-60x15 to 245-60x15.
Last edited by 72RoadRunnerGTX on Sun Apr 10, 2022 11:48 pm, edited 7 times in total.
moparmike
Re: 72’ Road Runner/GTX restoration(another appearance updat
Post by moparmike » Sun May 01, 2011 4:29 pm
Absolutely Beautifull Car.....My brother the charger fan loves the 71 superbee shown in the 1 pic.
PasiR
Post by PasiR » Mon May 02, 2011 10:25 am
Beautiful! Could you share part numbers for front calipers, adapters and brake hoses?
72 U Boat
Post by 72 U Boat » Mon May 02, 2011 11:19 am
Absolutely love the Rallyes, they complete the look! This body style, and that color, are perfect for those wheels! Perfect choice, good job!! :beer: :beer:
Post by 72RoadRunnerGTX » Tue May 03, 2011 12:29 am
PasiR wrote:Beautiful! Could you share part numbers for front calipers, adapters and brake hoses?
Thanks,
Rotors sourced from Summit, 11.75" Cordoba rotors.
Spindle bearing adapters from DoctorDiff to allow the larger bearing rotors to fit the 70-72' disc brake spindles.
Caliper adapters (AR000) are made by AREngineering and I sourced them from DoctorDiff as well.
Wilwood Dynapro 120-9692 lug mount calipers to fit the 1' rotors sourced from The Car Shop, cancelled my initial Summit order after they jerked me around for 6 weeks and still couldn't get me a ship date.
The hoses are Russell brand 15" straight female AN3 with a 90 degree 1/8" pipe to AN3 adapter at the caliper and a frame mount AN3 to inverted flare adapter to the brake line. I've had them for a while and don't recall where I got them, Summit maybe.
Last edited by 72RoadRunnerGTX on Sun Apr 10, 2022 11:49 pm, edited 5 times in total.
PasiR
Post by PasiR » Tue May 03, 2011 2:49 am
Great information! Appreciate your help.
