AIR GRABBER questions
ARI440
Post by ARI440 » Tue Jan 12, 2010 11:24 pm
Hi
where can I get the decals for the airgrabber
airgrabber ..........on the top of the trap door
shark decal .......... on the side
and 440 decal ...........on top of the marker ligth
also what size drill bit do I need to drill out for the studs ?
ARI
ARI440
Re: AIR GRABBER questions
Post by ARI440 » Tue Jan 12, 2010 11:26 pm
Post by 72RoadRunnerGTX » Wed Jan 13, 2010 2:52 am
I thought read a post over on moparts that you picked up your Air Grabber parts from B/E&A, here are some diagrams they have posted there. I would have thought these instructions would come with the parts.
Repo decals are offered on e-bay all the time. Not sure of the quality however.
Post by bruce » Wed Jan 13, 2010 9:37 am
I got the decals for mine from Year One. They look great, but I'm sure they'd be available from other vendors as well.
ARI440
Post by ARI440 » Wed Jan 13, 2010 1:43 pm
yes I got the scoop from B/E &A
I have the diagram too
I used a 1/8 drill bit to thread the studs in and chipped the fiberglass off a little bit
then went two sizes more and had a hard time threading the stud in
so I stopped there and asked for help here
dont want to over size the hole and cant thread the studs in
I will look for the decals
thanks guys :beer:
Post by 72RoadRunnerGTX » Wed Jan 13, 2010 3:10 pm
Ah! You’re talking about threading the studs into the bubble or door. Haven’t seen the B/E&A piece but I did install studs into a Stinger Fiberglass repo and it can be tricky. Hole needs to be big enough to prevent splitting of the fiberglass and small enough for the self tapping threads to bite. I recall having to use some resin/epoxy to reinforce some of the stud/thread installs. I also needed to repair some studs the same way on the original piece I ended up using on my car as well.
I still have one more OEM set of decals left from back in the seventies that I plan to use if I need to but should I need more now, Edited 1/21/10, after Eric's reminder below, I would buy from Performance Car Graphics. After speaking with David on the phone, very knowledgeable, I have placed an order with him for serveral items including a 72' version V8X reporduction stripe.
Last edited by 72RoadRunnerGTX on Thu Jan 21, 2010 5:05 pm, edited 1 time in total.
NOrrTH
Post by NOrrTH » Fri Jan 15, 2010 7:56 pm
I got mine from Phoenix Graphics as well but if you search Ebay, you will see all these decals, including the reflective shark
'71 GTX N96
Post by Eric » Fri Jan 15, 2010 11:28 pm
IMHO, Performace Car Graphics is the best for stripes and decals (except the little stuff you can get from ECS). David's colors are more accurate and he uses better materials.
PasiR
Post by PasiR » Sun Jan 17, 2010 1:10 pm
I got decals from Dante.
I have also one question about grabber bubble. Can someone share pics how the bubble is attached to the hood, especially rear edge. Who repop attachment kit?
Thanks.
Post by 72RoadRunnerGTX » Thu Feb 04, 2010 5:15 pm
I’ve been on the fence about re-installing the 72’ version of the V8X stripe on my car since the very beginning of its restoration. After reading the posts on this thread in regards to graphics venders and speaking with Dave at Performance Car Graphics I ordered one of his reproductions. Finished the install last evening and have yet to get the car out of the garage for some wide angle shots, weather forecast indicate it may be some time. I have never installed such a large decal before, feared screwing it up big time, his instructions for the process are dead on and the outcome is one very very small dust particle away from flawless.
Post by 1972RM23 » Fri Feb 05, 2010 9:05 pm
72RoadRunnerGTX wrote:I’ve been on the fence about re-installing the 72’ version of the V8X stripe on my car since the very beginning of its restoration. After reading the posts on this thread in regards to graphics venders and speaking with Dave at Performance Car Graphics I ordered one of his reproductions. Finished the install last evening and have yet to get the car out of the garage for some wide angle shots, weather forecast indicate it may be some time. I have never installed such a large decal before, feared screwing it up big time, his instructions for the process are dead on and the outcome is one very very small dust particle away from flawless.
VERY NICE ...but I like V8X stripes!
Post by Eric » Sat Feb 06, 2010 2:21 pm
Looks great....can't go wrong with Dave at PCG.
ARI440
Post by ARI440 » Tue May 11, 2010 11:02 pm
