Vinyl tops
- Smellslike1974
Vinyl tops
Do they sell canopy or halo vinyl tops or do you purchase the full vinyl tops and cut them?I was just looking in a restoration book for dodge and Plymouth and in 1974 the only vinyl tops they have are the full tops.And that's for $116.the price isn't bad but i was just curious because saving money would be great if i can buy exactly what i need for cheaper price.
Last edited by Smellslike1974 on Tue Dec 01, 2009 11:34 am, edited 1 time in total.
Re: Vynal tops
vynal topsSmellslike1974 wrote:Do they sell canopy or halo vynal tops or do you purchase the full vynal tops and cut them?I was just looking in a restoration book for dodge and Plymouth and in 1974 the only vynal tops they have are the full tops.And that's for $116.the price isn't bad but i was just curious because saving money would be great if i can buy exactly what i need for cheaper price.
is vinyl tops
- Smellslike1974
Re: Vynal tops
yeah,that really makes a difference.
- Smellslike1974
Re: Vynal tops
Changed it.now maybe i can get an answer.71440 gtx wrote:vynal topsSmellslike1974 wrote:Do they sell canopy or halo vynal tops or do you purchase the full vynal tops and cut them?I was just looking in a restoration book for dodge and Plymouth and in 1974 the only vynal tops they have are the full tops.And that's for $116.the price isn't bad but i was just curious because saving money would be great if i can buy exactly what i need for cheaper price.![]()
is vinyl tops![]()
Re: Vinyl tops
Legendary sells the full vinyl top (seams running along the roof) and canopy vinyl top (seams at the "A" pillars).
As far as a halo vinyl top in not sure.
Isn't that sort of like a full vinyl top except for trimed above the door openings.
Edit ... I see it is just like a full vinyl top with seams.
see picture
http://www.hamtramck-historical.com/ima ... lite_9.jpg
see picture
- Smellslike1974
Re: Vinyl tops
It would be canopy not halo.got confused.Im horrible today.
.thanks.
Re: Vinyl tops
So to answer your question: make sure you buy the canopy vinyl top not a full vinyl top and have it trimmed.
Since the seams are different between the two tops.
I have a canopy vinyl top from Legendary yet to put on my car but the seams are correct for canopy vinyl top and are on the "A" pillars.
- Smellslike1974
Re: Vinyl tops
Why would it need to be trimmed?A canopy is exactly what i need.I just didnt know if they sold them.1972RM23 wrote:So to answer your question: make sure you buy the canopy vinyl top not a full vinyl top and have it trimmed.
Re: Vinyl tops
there is quite a bit of extra material on vinyl tops, then you have to cut it to fit under the trim
Re: Vinyl tops
This car belongs to a member of the RRNest (I think) anyway it has a canopy vinyl top on it using a full vinyl top (seams in red) and trimmed off the back half; which in incorrect.
A correct canopy vinyl top will have seam (as shown is green).
- canopy vinyl.jpg (34.94 KiB) Viewed 30354 times
- Smellslike1974
Re: Vinyl tops
i think you can order tops however you want - what distance between seams, pillar seams, even without seams, at least according to paddock...
- Smellslike1974
Re: Vinyl tops
Mine had the seams that were mentioned. It ended right where If you followed the trim between the two side glasses It was even with that. Definitely Not original. I really don't know why someone would do that just to make It end a foot over. Unless maybe It got ripped or damaged near the end so instead of replacing they shortened It. I would have done the same.
Best pic of It I have before It was taken off.
Re: Vinyl tops
Don't know if this helps you sl74, but here is a pic of a 74 I parted out. It had a vinyl top on it. Here is where the chrome strip was on it. Sorry I don't have a better pic.
- Smellslike1974
