71 RR Wheelhouse Vapor Canister Shield?
Ronnman
Post by Ronnman » Fri Nov 06, 2009 1:40 am
Does anyone have a pic of the two sheilds (shown in the pics below) installed on their car? I'm missing the lower sheild shown on the right in the pic and was wondwering where it bolts.
Thanks,
Ron
(17.73 KiB) Downloaded 1166 times
71runnerm51
Re: 71 RR Wheelhouse Vapor Canister Shield?
Post by 71runnerm51 » Fri Nov 06, 2009 9:13 pm
I don't recall seeing the other shield on mine .... but that was this spring when I had the canister out :o
Post by Eric » Fri Nov 06, 2009 9:27 pm
best photos I have of my car at this time
(33.91 KiB) Downloaded 1110 times
(37.74 KiB) Downloaded 1110 times
Ronnman
Post by Ronnman » Sat Nov 07, 2009 11:06 am
Thanks Eric. I think those pics are good enough to get me going.
Ron
Post by Eric » Sun Nov 08, 2009 12:54 am
If I remember correctly, you'll find a slot in the frame rail that the wide tab on the lower shield (left side of the shield in your photo) fits into. The upper shield is attached first and the lower bolts over it.
sogtx
Post by sogtx » Tue Nov 24, 2009 10:07 pm
Its an awesome place to put fuel pump
I goofed when doing my 72 , its vapor canister is in front of the gas tank
So I never fitted one in when the cart was getting painted , wish I would have been paying attention
to detail .
Is AMD repopping those ? Those first pics look like restored or new tin ..
72GTX4SPEED
Post by 72GTX4SPEED » Sat Nov 28, 2009 1:03 am
sogtx wrote:Its an awesome place to put fuel pump
to detail .
amd is making those parts. when was your car made? mine was built in feb 72 and has canister in driver side wheel well like the 71's.
clem
Post by 72RoadRunnerGTX » Sat Nov 28, 2009 1:34 pm
The cut over point for that 72' canister change is described as "up to Mar 72 and after Mar 72" in the 72 parts catalog. I read that as April 1. 72 for that production change. I am changing over the 72' Sat I am currently bringing back to life from the early system to the later design.
Post by landon1 » Sat Nov 28, 2009 7:25 pm
72RoadRunnerGTX wrote:The cut over point for that 72' canister change is described as "up to Mar 72 and after Mar 72" in the 72 parts catalog. I read that as April 1. 72 for that production change. I am changing over the 72' Sat I am currently bringing back to life from the early system to the later design.
any chance of a detailed thread on that car like there was for the RR/GTX? :wink:
sogtx
Post by sogtx » Sun Nov 29, 2009 7:27 pm
to detail .
clem
Apri; ? , I think
