Peek a boo! (look in the blower wheel)
Project heater box, gross!
TX9GTXN96
- My Cars: Present: '71 GTX 440+4bbl 4-spd 4.10 Dana GW3 GW3 J68 louver
'71 RR 383 4bbl 4-spd 3.23 GY8 V1X - Location: NY
After I started to pull the heater box apart, I found this little surprise
He was quite mummified!
- (120.25 KiB) Downloaded 3168 times
My Mopars:
TX9GTXN96
Re: Project heater box, gross!
Yuck!
- (97.75 KiB) Downloaded 3164 times
My Mopars:
TX9GTXN96
He certainly tried to get out, note the bite marks on the plastic wheel! Poor little critter
- (65.86 KiB) Downloaded 3160 times
My Mopars:
TX9GTXN96
This is where he probably lived before tragedy struck
Wonder if there was ever another Broadcast sheet copy in there?
- (115.86 KiB) Downloaded 3157 times
My Mopars:
steved
mine had a rat nest and a big ol' snakeskin...
TX9GTXN96
Smart snake, easy hunting!
My Mopars:
steved
My GTX has A/C. I found that O'Reilly has a heater core for 49.99 (cheaper than my rad shop could fix it). I'll be picking it up today. The A/C condenser is getting a lookover at the local radiator shop, they're also dipping the gas tank.
I think when I put the halves of the heater box back together, i'm going to RTV the joint. the lower edge had this ultra thick tar like stuff just covering the bottom seam...I think it was a bandaid to keep the interior dry.
TX9GTXN96
steved- do yourself a HUGE favor and buy the heater/ac box restoration gasket and seal kit from this guy
http://www.restorick.com/products.asp?cat=9
My Mopars:
steved
A/C cars are different
I've got an A/C car. unless it's the same as the E-body set...
I wrote him about the set, and he's only got A/C B-bodies up to '70. the E-body kit looks good, but isn't the same.
Need a gasket set for 71-74’ b-body A/C housing? Jim over at Detroit Muscle Technolgies makes them.
Highly recommend, I used quite a few of his gasket sets on my 72' RR/GTX project.
Last edited by 72RoadRunnerGTX on Thu Oct 29, 2009 4:12 pm, edited 1 time in total.
steved
Funny...I just ordered from them around noon.
I'm going to go back for their firewall and exterior seal sets...
