1972 Road Runner/GTX restoration
Re: Continuing progress on the 72’ Road Runner/GTX
SWEEEEEEEEEET!!!!!!!!!!!!!
Re: Continuing progress on the 72' Road Runner/GTX
Finally home from the body shop, now I can put it back together.
Last edited by 72RoadRunnerGTX on Sun Apr 10, 2022 11:00 pm, edited 5 times in total.
does GA4 have a bit of a blue tint to it, or is it just the lighting? either way, phenomenal
After grilling my paint guy a little more about the color, turns out according to DuPont, the "modern equivalent" for the original 72' GA4 is a 98' Mitsubishi color (T52 Sydney Blue Effect). There are times it looks blue, other times I can see a slight green tint, and every so often it does look grey especially after dark. I'm not yet convinced it's a perfect match to the original color I remember. It does match well with the old paint chips for 72' I have however. Either way I am very pleased with the end result.
Last edited by 72RoadRunnerGTX on Sat Jun 13, 2015 11:39 am, edited 3 times in total.
indeeed - my car is supposed to be Intense Blue Pearl (common on late 90s Dodge Rams, Dakotas, etc. but if I park next to one, it's not at all alike...
i think anyone would be pretty jealous, regardless
The installation of the air grabber parts today marks the completion of the body\paint portion of this restoration. With a just few details left on the interior the car is pretty much done. Now if it would only stop raining here, I could go drive it.
Last edited by 72RoadRunnerGTX on Sun Apr 10, 2022 11:00 pm, edited 4 times in total.
- ajcpaperboy
- My Cars: '71 Road Runner
Your car looks GREAT, I wish I was working as fast as you are.
Your pictures of the Air Grabber are going to be very helpful
when I get to that point. Thanks
DixieSatellite
Your car is pure class - beautifully planned and executed.
Ian B.
Ian B.
Was able to get the car out of the garage today and get some decent pictures.
Last edited by 72RoadRunnerGTX on Sat Dec 17, 2022 12:54 pm, edited 6 times in total.
Great Job it is pure Mopar class. It has been a pleasure to watch your restoration from start to finish.
bandman
Wow, your car is breathtaking. Congratulations!!!!!
If I could ask one question.........What size screw did you use to mount the actuator bracket mount to the hood for the air grabber? I have been pondering that question for my car the entire winter.
Great car,
Dennis
Great car,
Dennis
Screw size is 10-24x ¾" captured washer. If memory serves me correctly, the factory A/G hoods had a nut plate affixed to the inside of the hood brace, the bracket mounted to that and allowed for quite a bit of position adjustment. The Satellite flat hood I used had all the holes punched but no nut plate so I created my own nut plate for this propose, unfortunately I don't have a picture of it. Basically four 10-24 square nuts welded to a sheet plate formed to conform to the backside of the brace.
I do appreciate all the complements received for this project over the last couple of years, thanks much all. I installed the door panels on the car tonight and basically there is not much left to do except clean up the body shop dust and go dive it. I am finding it hard to believe it's finally done.
I want to acknowledge the contribution of every author of every post I have read here on the nest over the last few years. A great deal of the knowledge learned here found its way into this project at some level. Although this project may be a wrap, I'm not going anywhere; I still have enough parts left over to someday put one of my Sats back on the road as a pretty cool daily driver.
Thanks again all,
Doug
Thanks again all,
Doug
Last edited by 72RoadRunnerGTX on Sun Apr 10, 2022 11:03 pm, edited 7 times in total.
sogtx
Re: 72’ Road Runner/GTX restoration
ugghh..
thats awesome ..
thats awesome ..
- (61.55 KiB) Downloaded 5120 times
Another day in Seattle without rain in the forecast, so I drove the car into town today.
Last edited by 72RoadRunnerGTX on Sun Apr 10, 2022 11:02 pm, edited 4 times in total.
That is one sharp car!!!
