RS23-71
Post
by RS23-71 » Tue Jul 29, 2008 11:20 pm
471Magnum wrote:So what's with the C12 code? Never seen that before. It's a shoulder belt code.
And no C16 code, but obviously factory console equipped.
I noticed that as well....... as soon as I saw that tag I ran all the options but then again its a windsor car.
Post
by 1972RM23 » Wed Jul 30, 2008 12:20 am
Here is a few photos of original 1972 RR's w/ N96 a V21/25.
Notice no black paint behind the fiberglass Air Grabber dome.
This photo also shows Air Grabber lettering on a 1972 air box lid ... factory for 1972 N96 cars?
Notice how if the paint continued behind the dome it would not run parallel to the V21 stripe (so it was not painted from the factory).
Side note ... V21 V25 stripes were available on any 1972 Plymouth Satellite 2-door.
Post
by 471Magnum » Wed Jul 30, 2008 6:28 am
RS23 '71 wrote:471Magnum wrote:So what's with the C12 code? Never seen that before. It's a shoulder belt code.
I'm thinking fender tag typo. Wouldn't be the first time.
"I can fix it... my old man is a television repairman... he's got the
ULTIMATE set of tools... I can fix it."
Post
by Eric » Wed Jul 30, 2008 12:13 pm
I see C12 codes on 72 tags all the time. Nothing out of the ordinary there.
Post
by 471Magnum » Wed Jul 30, 2008 12:34 pm
Eric wrote:I see C12 codes on 72 tags all the time. Nothing out of the ordinary there.
So what about the lack of a C16? Is that normal for 72?
Post
by Eric » Wed Jul 30, 2008 1:08 pm
I've not seen one with both C12 and C16 on the same tag. Don't recall (and don't have any info in front of me) what the C12 designates.
Post
by 471Magnum » Wed Jul 30, 2008 1:22 pm
According to two sources I have, C12 is "Shoulder Belts"
I've got pics of a couple of 72 tags at home. I'll check them tonight.
Post
by Eric » Wed Jul 30, 2008 6:07 pm
Ok, I have to take back an earlier statement. I have quite a few on record that have both the C12 and C16 on the tag. ALL C12 cars I have are Winsor built. This may be a Winsor only thing. Winsor did code the C16 on the tag when appropriate.
RS23-71
Post
by RS23-71 » Wed Jul 30, 2008 9:03 pm
So its not like axle codes with windsors? Sometimes there and sometimes not?
Post
by 471Magnum » Wed Jul 30, 2008 9:07 pm
Eric wrote: Windsor did code the C16 on the tag when appropriate.
Maybe. Check out my post on the 72 TX9 GTX
RS23-71
Post
by RS23-71 » Wed Jul 30, 2008 9:11 pm
Just did
Post
by 471Magnum » Wed Jul 30, 2008 10:00 pm
Okay, last highjack post on the C12 "controversy". Here's another Windsor car with the C12 AND C16.
Yet another FE5 N96 car. Popular combination in 72.
Don't know much about this particular car. It was on Ebay over six months ago.
- 6bcb_3.jpg (34.38 KiB) Viewed 17482 times
RS23-71
Post
by RS23-71 » Wed Jul 30, 2008 10:27 pm
Yeah sry for hijacking your thead but I'm learning stuff.... that last tag 471magnum posted was the 1st time I saw a E68 and D14 code so I had to look those up. =)
{edit} Weird after looking at around it lists the D14 = 3-Speed Manual Column Shift and it was only avail on 225 and 318 engines only?????? ??????
Post
by 471Magnum » Wed Jul 30, 2008 11:33 pm
That's a D34, not a D14.
N96RR1972
Post
by N96RR1972 » Thu Jul 31, 2008 7:44 am
OK ...So, Is it possible to get a console from the factory without it being on the fender tag?, Such as in this case?
