Ronnman
Post
by Ronnman » Mon Jul 21, 2008 5:40 pm
Currently on my Roadrunner I have a six pack coil bracket to which you are refering. Attached is an older pic of the coil bracket and the fuel line running along the inside of the valve cover and feeding from the back.
Ron
- 71 RR engine 05 small.jpg (142.76 KiB) Viewed 6027 times
Post
by landon1 » Mon Jul 21, 2008 7:46 pm
both look pretty good. never thought about running the fuel line so that it hooks up at the back instead of the front...looks like i'll be visiting the scrap pile, cutting wheel, grinder, and drill press soon
- My Cars: 1971 roadrunner
Post
by mopar71 » Tue Jul 22, 2008 11:27 am
Ronnman wrote:Currently on my Roadrunner I have a six pack coil bracket to which you are refering. Attached is an older pic of the coil bracket and the fuel line running along the inside of the valve cover and feeding from the back.
Ron
How does it run? I mean have you ever had any problems with vapor lock?
Ronnman
Post
by Ronnman » Tue Jul 22, 2008 1:36 pm
It runs great, never had and problems with vapor lock. Usually vapor lock occurs on the suction side of the pump. I am using the stock mechanical pump and the routing of the suction line from the tank is stock.
Ron
