extra firewall holes?
birdbrain
i'm doing the engine compartment in my 73 SSP, and after removing all the hardware from in there i discovered there are some holes that i don't think belong. they are approximately 1 inch in diameter and are just above and to the right of the throttle pedal. someone put freeze plugs in there and sealed them with sealer.......i'm thinking it must have had under the dash A/C at some point. this is a factory 400 / 4 speed car if that makes any difference???? oh yeah, you guys don't know of anybody making repro wheel lip mouldings for this car do you?........didn't think so.
- Smellslike1974
Re: extra firewall holes?
Im lostbirdbrain wrote: oh yeah, you guys don't know of anybody making repro wheel lip mouldings for this car do you?........didn't think so.
birdbrain
birdbrain
finally got a pic
just to the right of and below the throttle cable you'll see i put red X's on the ends of the freeze plugs currently in the offending holes. also if you look directly below the throttle cable just before the floorpan seam i painted a red arrow to the small hole i presume was a drain tube hole for an aftermarket A/C system maybe??????
- satellite SP firewall 007.jpg (137.06 KiB) Viewed 14930 times
DeLorean00
birdbrain
yep that wire is for the 4 speed. i haven't gotten everything out yet to paint. i just dropped the K frame tonight and plan to take it to my automotive machine shop and get it hot tanked for painting.......saves a lot of elbow grease and it's relatively cheap. this is my first time doing a total front end rebuild on a rubber mounted K frame. i bought the just suspension poygraphite K frame bushings, but i don't know for sure if i'm supposed to use all the factory shims on the rear bushings or not.....does anybody here know for sure? maybe i'll call JS tomorrow and see what they tell me on that......i need to get this thing back to rolling by the end of the weekend.
birdbrain
birdbrain
one more question
beside everyone's handle our body and cost levels appear as they do on the VIN plate and mine has RL instead of RP.......is that something i can change??? if so i can't figure out how.
