PG Classic Air Grabber Kit
Post by 471Magnum » Sun Feb 24, 2008 7:50 pm
So how complete is this kit?
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 37989&rd=1
Is there anything else I'd need other than a hood and vacuum can?
Anybody got a Satellite hood they want to sell, or trade (within a resonable radius of Evansville, IN) towards a GTX/RR standard hood?
air grabber
Post by rr6pak » Sun Feb 24, 2008 8:38 pm
This kit is complete...everything you need..
RS23-71
Re: PG Classic Air Grabber Kit
Post by RS23-71 » Sun Feb 24, 2008 9:34 pm
471Magnum wrote: Anybody got a Satellite hood they want to sell, or trade (within a resonable radius of Evansville, IN) towards a GTX/RR standard hood?
I wish I had a satellite hood to trade you.. I would do it in a heartbeat. Seems like if you can you should save the original hood just incase. Just a thought.
linemup
Post by linemup » Sun Feb 24, 2008 11:16 pm
I bought the bubble and door from them. Anyone got any ideas how to rig the door to stay open all of the time? There is no air grabber underhood stuff. This is just for appearance sake. Trying to figure out how to make it stay open.
ajcpaperboy
My Cars: '71 Road Runner
Post by ajcpaperboy » Mon Feb 25, 2008 1:23 am
I just saw this auction for a hood on ebay. The item number is #350029706676 I know it is not in Indiana but if the price is right
Fed ex will get it there. Good Luck.
fourforty6pac
Post by fourforty6pac » Mon Feb 25, 2008 1:38 am
You need all the fasteners the ones for the bubble, hard to find and pricey. You need the fasteners that hold the oval seal to the box. The seal that goes around the door and the pair for the sides of the door. You also need a switch bracket and a bezel. Oh! and the decals.I know there are a couple more smaller parts I'm forgetting, like the air cleaner. You will have to spend close to $500 more to get it done right. There's nothing like an Air Grabber! I didn't see a hinge either, so add a bit more.
71 air
Post by 71440 gtx » Mon Feb 25, 2008 2:06 am
1970-72 340, 383, 400 and 440 4-Barrel with fresh-air hood for B-body. 383 and 400 baseplates are different and sit higher on the carb than the others.
:beer:
the 440 one is hard oneImage to fine
Re: 71 air
Post by 471Magnum » Mon Feb 25, 2008 8:33 am
71440 gtx wrote:1970-72 340, 383, 400 and 440 4-Barrel with fresh-air hood for B-body. 383 and 400 baseplates are different and sit higher on the carb than the others.
I've actually got a 6 BBL set up, but with the non-AG base.
The AG is a long term project. I'm just putting a shopping list together at this point.
Re: 71 air
Post by 71440 gtx » Mon Feb 25, 2008 1:31 pm
so you have a 69 1/2 base ? 70 71 6bbl base will fit a ac car 70 -72
ihave 69 440 4bbl base fo my 71 gtx :beer:
Re: 71 air
Post by 471Magnum » Mon Feb 25, 2008 7:24 pm
71440 gtx wrote:so you have a 69 1/2 base ? 70 71 6bbl base will fit a ac car 70 -72
This is what I've got.
Re: 71 air
Post by Eric » Mon Feb 25, 2008 7:42 pm
Yup, that's the non air grabber base. The ones for a fresh air hood didn't have the shield on the front.
Post by 71440 gtx » Mon Feb 25, 2008 8:51 pm
Yeah, thats the non-fresh air one, but it will still work in an air grabber, I've seen lots of them that have the wrong one, but they still work.
Post by 471Magnum » Mon Feb 25, 2008 9:19 pm
This is a parts list provided to me by a friend. I need to compare it to the PG Classic kit.
  • Air grabber conversion:
    Hood
    hood bubble
    hood bubble door
    door hinge
    bottom of hood air box
    air box seal
    air box seal clips/bolts
    front air box door and hardware
    vacuum actuator
    actuator spring
    bracket welded to hood for actuator
    hose kit
    6 hose kit clips
    vacuum can with correct bracket
    vacuum T in intake to feed can
    air grabber switch, bezel, bracket, light
    actuator solenoid relay ( not needed, as you can close door by flipping switch) (you will need bracket for the solenoid that mounts to switch if you use solenoid)
    air grabber hood decal
    air grabber decal for hood bubble door
    4 bell nuts for rear of hood bubble
    misc fasteners
    air cleaner base-
    Air cleaner lid, filter. filter decal. pie tin (71)
This might good info for the tech archive.
Post by 71440 gtx » Mon Feb 25, 2008 9:46 pm
and a three prong hose plug for hole in fire wall and hose kit clips for in side :beer:
car
Post by rr6pak » Tue Feb 26, 2008 5:14 am
Dont forget...and a partridge in a pear tree...LOL
just kidding :D
