Which oil??
aerodynamic
Which oil??
Post by aerodynamic » Thu Jan 24, 2008 1:24 pm
Guys, I'm thinking of building a 440. I have access to one locally real cheap, unmolested. Do you guys recommend synthetic, and which weight?
73 Road Runner 400 auto
Post by mopar71 » Thu Jan 24, 2008 4:46 pm
I was told to not use synthetic till after the breakin of the engine,then use synthetic.10w40-30
1bluegtx
Post by 1bluegtx » Thu Jan 24, 2008 4:49 pm
It depends but if you are using a flat tappet cam i would not use synthetic.Read the last paragraph from this crane cams bulliten:
http://www.cranecams.com/pdf/548e.pdf
You also might consider an additive that contains zddp (zinc), helps lubricate the lifters and other parts.
Its not numbers matching
It doesn't run on pump gas
11.73 at 115mph
Post by mopar71 » Thu Jan 24, 2008 5:56 pm
