Which oil??
- aerodynamic
Which oil??
Guys, I'm thinking of building a 440. I have access to one locally real cheap, unmolested. Do you guys recommend synthetic, and which weight?
73 Road Runner 400 auto
It depends but if you are using a flat tappet cam i would not use synthetic.Read the last paragraph from this crane cams bulliten:
http://www.cranecams.com/pdf/548e.pdf
You also might consider an additive that contains zddp (zinc), helps lubricate the lifters and other parts.
- mopar71
- My Cars: 1971 roadrunner
You bring up a good point
,I was reading hotrod mag about this problem,so here is good reading for some.
http://www.hotrod.com/techarticles/engi ... to_06.html
http://www.hotrod.com/techarticles/engi ... ction.html
http://www.hotrod.com/techarticles/engi ... index.html
