Airgrabber HELP! What is the hole size to cut into the hood
- scottish440
I need to know the hole size to cut in my stock satellite hood...in pictures that I have it shows bigger top hole than the bottom..
Is there anyone who has documented a 71-72 airgrabber resto?
thanks scottish440
_____________________________
I have a bunch of 71and 72 rr parts
and reproduce OE stripe kits for many mopars...
thanks scottish440
- scottish440
Check with 71440 gtx
http://www.roadrunnernest.com/Forum/vie ... highlight=71440 gtx wrote:You need a complete air grabber switch, with hoses, vaccuum canister that goes on the pas. side inner fender, the hood activator and the bracket that holds it into place and the round plastic clips that hold the hoses in place. You will need to cut the hole in the firewall for the hoses to go through. Because I'm a Mopar nut and willing to lend a hand to fellow Mopar enthusiasts, I can provide a template from an original hood to make the proper cut outs if you so require.
Do you still think that you want an air grabber for your GTX? Give me a shout if you need anymore help.
Kevin
here are a couple of photos of when I made one from a satellite hood. Basically there is no hole to cut on the underside, you just cut out the braces. The hole above lines up with the curve of the brace at the back and is cut a little larger than the brace at the front. I had the benefit of using an AG hood as a template at the time.
- IMAGE2.jpg (52.2 KiB) Viewed 22928 times
- scottish440
Air Grabber
Here are the results of a not so lazy sunday afternoon....
- scottish440
I used the Stenger fiberglass bubble and air box....and the now available "china" made orange flapper door...
- scottish440
My boy Tyler is in the last picture....he was very excited that i am putting the airgrabber set-up on my 72 rr.....he likes it cause' my car will have a mouth...
Lastly I cannot say enuff about the amount of fabbing you will have to do to get the aftermarket parts to fit onto the hood correctly....
I would love to do a step by step write-up on installing this set-up with pictures and mesurements....scott
- scottish440
It is a 1964 Jensen CV8 with a Chrysler big block and cable shift 727 transmission....They were the earlier version of the famous 440 powered Jensen Interceptor.....Made by the same company that built the subeam tiger, volvo p1800, and the austin healy.......there is a bunch of other neat stuff about the motor......let me know and I will fill you in....scott.....I have exceded my 256k limit or I would give you a pic
