Rear window defogger wire routing and switch position
My Cars: 71 Satellite
Post by 71Satellite98661 » Tue Sep 07, 2021 1:05 pm
Of the three possible locations, was there a rhyme or reason to which switches were mounted where? I selected the left most position for RR defogger switch. That is the only switch I have. Also, can anyone post a photo of the wire routing under the package tray. I believe there are 3 clips. Finally, anyone use the repop plenum from Classic Industries for use with both defogger and speaker? How did it work out?
Re: Rear window defogger wire routing and switch position
Post by sdweatherman » Tue Sep 07, 2021 11:01 pm
Hey Tyler, you seem to come up with some of the toughest questions for us. I looked through my disassembly pictures and could not come up with a shot that has any clues on where the defogger wiring or time delay stuff is mounted. Hopefully someone else will have some insight on this. Good luck!
Post by 72RoadRunnerGTX » Sun Oct 17, 2021 8:17 pm
