22 to 26 radiator
Philcollins1
My Cars: 1972 Plymouth Satelitte Sebring
22 to 26 radiator
Post by Philcollins1 » Thu Aug 13, 2015 6:35 pm
Does a 26" radiator fit on a car with a 22"?
Any sheet metal modifications?
Re: 22 to 26 radiator
Post by 71bird » Thu Aug 13, 2015 9:49 pm
There is an additional peace of sheet metal that has to be install on one side. I think it is available from most of the vender adoring to where you live.
moparmarks
Post by moparmarks » Thu Aug 13, 2015 11:08 pm
You can buy the right side core plate but the left side is also different between 22" and 26". Just did this on a customers car. 1/2" difference on the left side. FPM also shows different plate on the left but everyone thinks you just need to change the right side..
Southwestern Sheet Metal
71-4 B-body
Philcollins1
Post by Philcollins1 » Fri Aug 14, 2015 7:58 am
Any pictures of what is involved?
Any suggestion of vendor?
Thanks.
Post by moparite » Fri Aug 14, 2015 10:06 am
You have to cut the old rad support plate off and weld on a different one. If you don't want to spend the money on new sheet metal you can cut a strip out of the old one and weld it to fit the 26" rad.
https://www.yearone.com/Catalog/chrysle ... _-brackets
Philcollins1
Post by Philcollins1 » Fri Aug 14, 2015 3:33 pm
So the driver side is the same 22" or 26"?
moparmarks
Post by moparmarks » Fri Aug 14, 2015 5:36 pm
No they are different but can make the left side work. I'll get some pictures of one that we are doing now.
Also what year is your car? The right side plate being made is for 71-2. 73-4 is different. Also we got one off of e-bay for 130.00
71-4 B-body
Philcollins1
Post by Philcollins1 » Sun Aug 16, 2015 1:40 am
1972.
