gas tank strap, pad insulation
E86 GTX
My Cars: 1971 440 GTX Tor Red getting TLC in my home shop...
1972 Satellite parts car
383 Roadrunner back in the late 70's
Post by E86 GTX » Wed May 30, 2012 1:04 am
OK I did not have the privilege of removing the tank from my 71 GTX. Did it have a pad between the trunk pan and the tank? Did the straps have rubber insulation between them and the tank?
Thanks: Your Friend Ben
gary
Re: gas tank strap, pad insulation
Post by gary » Wed May 30, 2012 5:45 pm
Yes pad,No insl.on straps. :beer:
Post by sdweatherman » Wed May 30, 2012 11:27 pm
If you want a pic of the pad to see what it looks like, let me know. I have not reinstalled mine yet. Scott.
E86 GTX
Post by E86 GTX » Thu May 31, 2012 12:10 am
thanks Scott. I have no what it's supposed to look like. are the ones on ebay correct ?
Post by 1972RM23 » Thu May 31, 2012 3:56 pm
I'm replacing my fuel tank in a few days.
What is the correct procedure for starting a car with no fuel in the lines with a replaced tank?
Do you fill up the fuel filter with a little gas to help it draw fuel through the lines?
E86 GTX
Post by E86 GTX » Thu May 31, 2012 10:57 pm
I pore a couple table spoons gas in the carb. Replace the breather to prevent fire, then start. You may have to do this 3 or 4 times depending on how good your pump is. This saves a lot of wear on the starter. If you choose to use the starter alone it will work but be careful not to over heat the starter by over cranking. That's what I always did when starting a car that has run out of gas.
. Your Friend Ben
Post by sdweatherman » Fri Jun 01, 2012 10:25 am
Here is the pic of the gas tank pad. It measures 22.5 x 25.5 x 3/16 and is made of a cardboard/felt type material. Not quite sure what its real name is. Scott.
E86 GTX
Post by E86 GTX » Fri Jun 01, 2012 11:04 am
Thanks Scott. That has me thinking twice about the e-bay pads. They are foam and that makes me think it might hold moisture.
. Thanks Again: Your Friend Ben
gcoupe72
Post by gcoupe72 » Fri Jun 01, 2012 6:08 pm
Back in the early '90s, Rick E. at Mopar Action restored a '72 RR.
He used roofing felt, which I think is a little thin, but a good match for the material.
Maybe doubling it up would be about the right thickness. If you've got a piece try it.
The best part, IT DOESN'T SHOW!
Post by sdweatherman » Sat Jun 02, 2012 5:19 pm
Just took a look at yearone.com and they have the reproduction pads. They have a note that says the reproduction pads are foam, where the originals are tar. So the felt paper idea by gcoupe72 looks to be right on track. When I look again at my pad, it does have a thick felt/tar paper consistency. Hope this helps! Scott.
general
Post by general » Sun Jun 03, 2012 10:29 am
E86 GTX
Post by E86 GTX » Sun Jun 03, 2012 11:33 am
Thanks guys. I think i will go with roofing felt. Scott, how many layers will it take to make it as thick as
original?
,................ Your Friend Ben
Post by sdweatherman » Tue Jun 05, 2012 8:49 pm
My gas tank felt measures 3/16" thick.
E86 GTX
Post by E86 GTX » Tue Jun 05, 2012 10:59 pm
thanks Scott
71ChallengerSE
1971 Dodge Demon 'Sizzler'
Post by 71ChallengerSE » Tue Jun 12, 2012 4:35 pm
Dixie Restorations says they have the correct pad, but thats if you want to spend $80 on a little pad that no one will ever see! :lol:
