Hi Jacker
driver
My Cars: 71 Plymouth Satellite
Hi Jacker
Post by driver » Sat Jan 15, 2011 6:30 am
Hi
i like the picture here on top ... from the nest (the comic blue car) :D
so i would like to bring the ass more highly...
I think i can handle it with hi jacker... but i dont know witch kind of jacker
i can use... can me someone give little support... which fit for the 71 satelitte...
thanks
Re: Hi Jacker
Post by CtownRunner » Sat Jan 15, 2011 8:30 am
Hello,
Some use Heavy Duty leaf springs to give the rear more lift and lower the front torsion bars just a little.
Different tire sizes front to rear also play a part.
Air shocks are not the standard way to get the mean stance U are looking for.
I know what you mean but any air shock can do what you want if you go that route.
driver
Re: Hi Jacker
Post by driver » Sat Jan 15, 2011 9:58 am
ok thanks...
i have no plan about leaf springs... :cry:
do you have an internet link for me.. that i can see one, thats fits...
or what car has equal springs.... ?
how are they divided ? weight -strength - size
i remember 20 years ago... my friend has an camaro with hi jacker...
it still runs good and he had never problems... why is this way not good ?
Thanks.... best regards :)
Chris
Re: Hi Jacker
Post by moparite » Sat Jan 15, 2011 11:10 am
The prolonged use of air shocks can damage the upper shock mount bracket. It will start to crack from the stress. Trust me. I had a Challenger that the springs where beat and someone put air shocks on. It was so bad you could move it with your hand. I welded all the cracks took off the air shocks and fixed the springs.
moparmike
Re: Hi Jacker
Post by moparmike » Sat Jan 15, 2011 12:42 pm
When I switched to 15`s instead of 14`s I took the car in and had an extra leaf spring put in and that gave me enough clearance and height. I also adjusted the front end up a bit when I removed my small block and installed a 440 as the weight difference was huge. My car seems to be sitting nicely
front sat.jpg (8.98 KiB) Viewed 25233 times
BigBlock
(Satellite Sebring Plus)
Re: Hi Jacker
Post by BigBlock » Sat Jan 15, 2011 9:58 pm
Mine was raised up by having a machine shop "re-bend" the leafs. It gave them their "spring" back. lol <----pun.
It also raised the rear up significantly. I am trying to get mine down again though :(
Re: Hi Jacker
Post by CtownRunner » Sat Jan 15, 2011 11:50 pm
http://chucker54.stores.yahoo.net/superstock.html
These are like the springs I have on my car.
When I got my car the spring were sagging and air shocks were in place.
I got KYB shocks and super stock springs.
driver
Re: Hi Jacker
Post by driver » Sun Jan 16, 2011 12:03 pm
thanks....
i would like to have it little bit higher than you...(like 100mm more) :)
steved
other stuff
Re: Hi Jacker
Post by steved » Sat Jan 22, 2011 11:28 am
does anyone just make a longer spring shackle? (the pivoting part where the spring attaches the frame in the rear) some aftermarket companies made slightly longer ones to work with the stock springs.
Re: Hi Jacker
Post by ILUV72RRs » Sat Jan 22, 2011 1:33 pm
Generally a longer spring shackle doesn't work. It'll pull the spring down, but it doesn't really raise up the back of the car. So you wind up with your springs even more exposed. Trust me, I tried it when I was young. I wound up taking the car to a spring shop, and having them rearc the springs. You tell them where you want the car to sit, and they know what to do. Yes, it's not exactly cheap. But you get what you pay for.
driver
Re: Hi Jacker
Post by driver » Sat Jan 22, 2011 2:57 pm
how much is it ?
and what is to do ?
Re: Hi Jacker
Post by ILUV72RRs » Sun Jan 23, 2011 1:21 am
Well, to be honest with you. I see you live in Germany. Don't know where you would take the car there to have the job done. Here in the states they have shops that do rear springs. You take the car to them. Tell them what you want, and they either rearc the spring, or put another one in the assembly that has more arc to it which forces the other springs to conform to the new one. Price? I couldn't tell you. I did that to my '65 Satellite. Which was back in 1968! Since then on my other cars I've always used Gabriel air shocks with no problems. But I have known guys who did have problems with the top shock mount breaking loose in their car.
Re: Hi Jacker
Post by CtownRunner » Sun Jan 23, 2011 11:42 am
The picture is before new springs and shocks.
It is higher now all the way around.
Same tires and wheels.
driver
Re: Hi Jacker
Post by driver » Mon Jan 24, 2011 12:44 pm
do you have a picture from the modification....?
i would like to see it ....
Re: Hi Jacker
Post by CtownRunner » Tue Jan 25, 2011 7:21 am
Sorry, no pics in years.
Really should but last pics are of us doing some body work.
