VALVE SPRING PROBLEM!
Okay.When i got my cam,i ordered the recommend valve springs also.First problem was i had with these springs are that my valve spring compressor couldn't be used with them.New springs have the outside spring,and damper and another smaller spring.So the teeth on the compressor couldn't reach to the center to hold the center spring in,it kept shooting out.Finally we went and got a bigger compressor,same problem so we welded longer teeth on it.I got the firsts spring on the head...NOW i have another problem.These springs wont go over the exhaust boot on my valve.WTF!The boots are new that came in my gasket kit.The two springs inside sit right on it.
Can someone PLEASE tell me a solution to this.Do I need new boots and all to go with these double springs???There was no mention of me needing anything with the springs.Ill take pics in a little bit ,check and update.
Its one thing after another.
Re: VALVE SPRING PROBLEM!
You can see where it hits the boot.
Is it possible to use intake oil seals on the exhaust valves???Because that my only solution as of now.
outside spring,and damper and another smaller spring. on a 318
outside spring,and damper on a 340 318 360 yes
wrong springs
wrong springs
How can that be?lunati recommended the springs for my cam.....
because Those springs are for a 0.590/0.640 lift cam to use the one you have.than you use race valve seals p3690963
Rechecked the cam info.My cam is the correct cam for my engine.Rechecked springs.Springs are correct springs for my engine and cam.I'm not sure why you say they are wrong springs.Ill post all the info on here if you think i have the wrong stuff.
When you use double or triple springs you cannot use stock valve seals.You have to use teflon ones like these:
http://www.summitracing.com/parts/CCA-505-16/
But these require the valve guides to be machined!
Or if your guides are in good shape you might be able to get away without using any seal.
THANKYOU!For your help guys.
Im now questioning why lunati didn't recommend these on this paper that arrived with the cam. -_-
These are correct,correct?
http://www.jegs.com/i/Comp+Cams/249/505-16/10002/-1
Should work,still have to have the heads machined.
Jegs sells the cutter if you want to do it yourself.
Why?Its a mild cam.
cam 268/276 0429/0444 p 4120249
cam 280/280 0 474/0474 p 4120249
cam 284 /284 0 484 /0484 p 41 20249
cam 292/ 292 0.508/ 508 p5249847
p4120249 single/ damper wire dia 0.206
p5249847single/ damper wire dia 0,207
Nay.My cams not there..
my Cam VV
http://www.jegs.com/i/Lunati/638/60401LK/10002/-1
And the recommended springs are #73949
Im just going by what i was sent,not saying all this like i know.
my Cam VV
Cam and Springs are fine.The problem is with the dual springs the inside diameter is reduced,hence the interference with the stock seal.The steel valve guide on the head has to be cut to a smaller diameter (.530) so the smaller teflon seals will fit.Not that big of a deal.You can buy a cutter and do it yourself with a drill or you might find a machine shop that will do it cheap since your heads are disassembled.About an extra 80.00 or so.
