manifold gaskets?
Clone Runner
manifold gaskets?
ok, i tore the top of the motor off to check the cam for wear, its fine, just wanted check previous owner installed it, when they put it together they went gasket, valley pan, gasket, manifold. is that correct? i'm new to big blocks.
Adam
1972 Road Runner (clone)
- RON71rr
Re: manifold gaskets?
Factory cast intakes used just the valley pan, no fiber gaskets. I like to use the fiber gaskets with the valley pan for aluminum intakes, some say it's not needed. Just my preference.
i've never even seen the paper/fiber intake gaskets - i just use the valley pan with a little gasket sealer around the edges
landon1 wrote:i've never even seen the paper/fiber intake gaskets - i just use the valley pan with a little gasket sealer around the edges
That's what's on mine:
- (265.81 KiB) Downloaded 399 times
