Brake bleeder
Brake bleeder
Post by mopar71 » Mon Jun 16, 2008 12:21 pm
I was looking thru my hemmings book and came across a brake bleeder and thought, what a great idea.This bleeder has a check valve built in so when you bleed the breakes it prevents any air and contaminated fluid from going back into the caliper. SB3824 for the front and- - SB51624 for rear drums.They are: $7.00 each.I will pick up 4 of these for my brakes.
:beer:
Here is the site:http://speedbleeder.zoovy.com/
speed bleeder
Post by rr6pak » Mon Jun 16, 2008 4:16 pm
Mopar71, I tried the web site. I couldn't get it to come up. Is it spelled right? I'm interested in looking at them
Post by Smellslike1974 » Mon Jun 16, 2008 4:41 pm
Its works fine for me,try again?if not,just paste the link in google and search it,a link to the website will come up. :beer:
bleeder
Post by rr6pak » Mon Jun 16, 2008 6:39 pm
I got the site this time :D
ROGERLEE
Post by ROGERLEE » Tue Jun 17, 2008 12:20 pm
aren't all bleeder valves like these??they look just like the regular ones found already on your car, unless the ones on your car have just a straight hole for the fluid to pass??
Post by mopar71 » Tue Jun 17, 2008 6:16 pm
No, the stock bleeders do not have the check valve in it,they are a straight hole just to bleed air and contamination from the brake lines.They do look similar but internally its different.
bleeders
Post by rr6pak » Tue Jun 17, 2008 8:10 pm
mopar71 wrote:No, the stock bleeders do not have the check valve in it,they are a straight hole just to bleed air and contamination from the brake lines.They do look similar but internally its different.
We have the same type bleeders, for the brakes, used on all types of our aircraft. I didn't know someone was making them or had made them for the general public.
dragman440
Post by dragman440 » Wed Jun 18, 2008 4:25 pm
Summit Racing and Jegs sell them
Post by mopar71 » Wed Jun 18, 2008 9:05 pm
Really,I get their catalogs all the time and never saw them :oops:
dragman440
Post by dragman440 » Thu Jun 19, 2008 3:58 pm
