Mystery of the Howling Bearing(s?)
billzilla
Post by billzilla » Wed Mar 26, 2008 5:10 pm
I think my rear left bearing(s) are howling! When I corner right its particularly loud. Which ones might be at fault and who stocks these ?
73X
Post by 73X » Fri Mar 28, 2008 1:15 am
any auto parts store have them
billzilla
Post by billzilla » Fri Mar 28, 2008 7:00 pm
Yes, but which ones? Aren't there two on each side?
73X
Post by 73X » Fri Mar 28, 2008 9:33 pm
one on each side in the rear, you have to pull the axle out to change them, need to be pressed on.
billzilla
Post by billzilla » Sat Mar 29, 2008 2:03 pm
Okay, great - I knew I'd need to use a press, wasn't sure if there were two on each end or what. Thanks!!!
billzilla
Post by billzilla » Mon Mar 31, 2008 12:36 pm
OK, I give up. I've been on Rock Auto and I cannot for the life of me figure out which bearings to get for this car. They have different sizes, it seems, from every manufacturer and their descriptions are vague so I have no idea what I'm getting. My shop manual is at my brother's place while he bones up on the front suspension job we're going to do.
Can someone give me actual part numbers for inner, outer bearings for the rear as well as the oil seals and dust cap? I mean, I think I have the seals and cap figured out - but the bearings are just totally confusing the way RA has them listed.
Thanks!!! :help:
1bluegtx
Post by 1bluegtx » Mon Mar 31, 2008 7:45 pm
billzilla wrote:OK, I give up. I've been on Rock Auto and I cannot for the life of me figure out which bearings to get for this car. They have different sizes, it seems, from every manufacturer and their descriptions are vague so I have no idea what I'm getting. My shop manual is at my brother's place while he bones up on the front suspension job we're going to do.
Thanks!!! :help:
OK first thing...what size rear end you working on? there is only one bearing pressed on the axle.The inner bearings are part of the ring gear carrier i dont recommend you mess with these unless you know what you are doing.Dust caps? are you talking about the front wheel bearings or the rear axle bearings?
73X
Post by 73X » Tue Apr 01, 2008 3:02 pm
maybe you should bring it to a shop.
