71 runner option questions
I had a similar post on moparts.
The question was about having the turn signals on the fenders.
The car was:
383
AC
Cruise
auto
hood pins
fender mounted turn signals.
Someone had mentioned that this combo (signals) was only on air grabber.
Can anyone lend some insight?
Fenders appear to be original, due to paint runs from fender onto core support.
thanks
The car was:
383
AC
Cruise
auto
hood pins
thanks
- fourforty6pac
Welcome to the 'nest
You've read my comments on moparts....standard Satellite and air grabber cars had fender mounted turn signals, standard roadrunner/GTX hood cars had them hood mounted. I've only seen one exception to that, a very early build car that was probably an assembly line mistake.
does your car have the stock front clip? if so it would be easy to tell (if there aren't holes in your fenders, they would be on the hood...i'm also assuming by having hood/fender signals, you have the light package (A01)
from your vin i thought you could determine date of production - maybe not (i have my broadcast sheet too) wish i had my vin on me, cuz mine was early (aug of 70) - my thinking is that sequence number could determine aprox. build date
- My Cars: 71 GTX
My old 71 Runner A/G car did NOT have fender mounted T/S....Never seen any mounts on the fenders either when I removed them for rust repair....
- 71rr1.JPG (27.63 KiB) Viewed 16819 times
- 71rr.jpg (14.8 KiB) Viewed 16819 times
71rr
its a option light package (A01) on 71 rr gtx rh ssp71GTX wrote:My old 71 Runner A/G car did NOT have fender mounted T/S....Never seen any mounts on the fenders either when I removed them for rust repair....
its not standard equipment with a/g hood
birdbrain
