qurter panel emblems? Are they stick on
linemup
Are the RR emblems for the 72 the same as the 69 RR emblems? Someone sad that the 72's are stick on. If so, where is the cheapest palce to get them? If they are the same with teh pegs on the back, I need some good pics so that I can see where the holes need to be drilled.
- moparmodeler
DeLorean00
IIRC the stripe and decal placement sheets show where these go. Check out the factory documentation over on Barry Washington's website.
71s had pins and I assume 72s were the same. Don't buy the repros from year one, they're way wrong in appearance.
linemup
DeLorean00
Were you talking about my RR emblems? Every RR I see on the internet has them right there. Am I wrong? Now I'm worried. LoLlandon1 wrote:the satellite emblems are stick on......ur "rr" emblems are low, but that's how i have my ssp ones, cuz i like the look better than being up high....rr emblems i thought were all stud-type
DeLorean00
I checked it out, and you are right. 1971 has the emblems higher in kinda a random spot. 1972 has them lower about where mine are. Once again I am no expert, I am only going off picture's i find on the net.landon1 wrote:yeah, they go up higher on the quarter panel(71 for sure....um if it's a 72 i def could be wrong)...a lil above and forward of the wheel arch(71)...hard to describe
bandman
DeLorean00
