Help! New seats don't fit...
billzilla
Post by billzilla » Sun Feb 17, 2008 2:53 am
I got '72 B Body seats (out of a Barracuda) - they look identical to any Sat/RR/GTX '72 seats. I was told that they match up 100% to '71 bolt holes.
The space between the front and back bolts on one rail of the seat that came out of the car (bear in mind it originally had bench and was fitted with buckets) is about 12". On the new car, it's about 8-9".
In short, the new seats have different bolt spacing... And the bolts seem welded in or something - they're not budging if I try to tap them out of the rails.
Any ideas? :(
Post by CtownRunner » Sun Feb 17, 2008 7:16 am
Had similar problem when I went from bench to bucket in my 71RR and my brothers 70rr with after market buckets.
The bolts where welded in. We cut them off and ground flush then replace with similar size bolts in the holes with the correct spaceing to fit the holes in the car floor.
PINA!
Post by Smellslike1974 » Sun Feb 17, 2008 1:12 pm
When i took my bench out it was only 2 bolts at each and,i saw no other holes where a bucket seat would go in,maybe the to original holes would be fine for the side of teh bucktes closer to the doors but the other ones you might have to make holes for them
billzilla
Post by billzilla » Sun Feb 17, 2008 1:45 pm
My Satellite had buckets when I got it (but it originally had bench).
I don't know if the seats that are in there are wrong, the holes wrong or the new '72 Charger seats wrong, but they don't line up.
I originally said these were Cuda seats, but they're Charger. Everyone said they'd fit, including the guy I got them from.
This is a major drag, not just because I gave $300 for these last night, but that the seats I have are seriously screwed up, at least the driver seat. The frame seems bent or something and it sits WAY back and I can't adjust it to sit upright properly.
Post by Eric » Sun Feb 17, 2008 2:20 pm
As I'd said in the previous post, there were two hole locations (differing side to side) for bench and bucket cars. The photo shows bench location (taken from under the car)....you can barely see the other hole only in the brace (not through the floor pan) just below. Both front and back align with the welded in bracing shown. Look and measure underneath, your stud to stud (studs on the seat track not bolts) spacing should match the opening spacing in the brackets.
Post by 71440 gtx » Sun Feb 17, 2008 6:50 pm
bench and bucket cars is the same hole locations diver's and back to 1 hole 7in from the in side rocker
15 in from 1 hole to 2 holes for the buckets
12 in front to back for the holes seat track :beer:
my 71 gtx is buckets car
my 71 satellite is bench seat car
1bluegtx
Post by 1bluegtx » Sun Feb 17, 2008 8:21 pm
This photo shows where the holes for bucket seats need to be:
billzilla
Post by billzilla » Sun Feb 17, 2008 8:55 pm
Well, there's no spot welded bracing plate, just a plate that the bottom bolt threads up through (inside holes closer to driveline). They all seem to be in the right place, but I will take pics tomorrow when the carpet is totally out of the car.
Post by Eric » Mon Feb 18, 2008 1:17 pm
The reinforcing plates only came on bucket seat cars, not on bench. Most people don't add them when they convert to buckets
