Front suspension restoration
Capsule
Post by Capsule » Tue Sep 11, 2007 2:27 pm
Hi guys,
I would like to ask you if you have any experience or recomendations regarding the front suspension bushings.
I dunno if I should get the standard rubber ones or the polygraphite ones.
My garrage buddy tells me that I should just get the less expensive standard rubber ones unless I'm going racing, which I'm not.
On the other hand the improoved handlling from the poly bushings would be recognizable during normal driving too, right?
I have my eyes on P-S-T bushings, any experience with their product?
Thanks,
Capsule
Post by road chicken » Tue Sep 11, 2007 6:05 pm
I used the poly bushings everywhere... including the rear spring eyes and shackles. I wouldn't go back to rubber. It makes a huge difference in how fast the car sets into corner and how stabile ( sp?) it stays through the corner. Even for someone whose not "handling orientated" it makes for allot more sure footed car. The ride quality is not seriously affected because that is more a function of spring rate , antisway abr rates and your shocks. However you will lose some isolation because the polys hold the suspension parts where they are supposed to be instead of squishing around like the rubber does.
Just be sure you get the graphite impregnated polys- if not they will sqEEEEEk like an overstressed bed spring, :D well for the first 5000 miles anyway.
Post by CtownRunner » Tue Sep 11, 2007 7:30 pm
I prefer all my suspension parts from Just Suspensions.
PST has a weido for an owner. I just can't support the guy.
moparmodeler
Post by moparmodeler » Wed Sep 12, 2007 12:53 am
A good stereo system will muffle the squeak of new poly bushings. Purple Hornies will do the trick to. If you do both you will definitely be covered. But be sure to check your local noise ordinance laws.
Post by CtownRunner » Wed Sep 12, 2007 6:00 am
Just Suspension parts are much better quality too. Be careful and check out the parts. Call J.S. they are friendly and helpful.
KeithRichards
My Cars: 1972 Plymouth Road runner 4 speed. 652 HP Street Sleeper
Re: Front suspension restoration
Post by KeithRichards » Thu Sep 13, 2007 7:07 pm
Capsule wrote:Hi guys,
Thanks,
Capsule
Talk to Dick at http://www.firmfeel.com as he help with our 72 RR and it handles very well and we are very impressed for the whole cost. He is in Washington State.
"Ya Gotta Have BIG Ones!"
http://www.speeddemons.com
71Runner
Post by 71Runner » Wed Sep 19, 2007 12:57 pm
"I used the poly bushings everywhere... including the rear spring eyes and shackles. I wouldn't go back to rubber."
+1.
Capsule
Post by Capsule » Thu Sep 20, 2007 3:36 am
Well, I guess Polygraphite bushings is the way to got then! :-D
Thanx guys!
Capsule
patrick
Post by patrick » Sun Sep 30, 2007 12:56 pm
This topic has been discussed in-depth on many-a-forums. The concensus is to either go with Moog parts (Firm Feel is a great source) for all rubber, or any company for poly since all bushings are the same, whether they're called "polyurethrane" or "polygraphite" or "poly-by-golly", and if you go with poly to use rubber on the lower-control arm bushings, or get the extra piece from Firm Feel if you use poly on the LCA.
http://www.firmfeel.com/adjstrut_b.htm
100% Death Proof
Post by CtownRunner » Sun Sep 30, 2007 7:53 pm
It used to be we could go down to the parts counter and ask for about anything for your beloved Mopar and be reasonably confident we would receive a quality part. Well, at least some of us can remember that far back. Today’s global economy and increasing pressure to make the stock holders happy has caused corners to be cut. Even some of the brands we once considered top tier have fallen in quality. Enter Just Suspension.
Just Suspension specializes in, well... suspensions. While they do provide parts for those other brands, they really cater to Mopars, including C Bodies. Most of their suspension parts are custom built to their own design and specs in the Midwest, yeah, the USA!
In an effort to raise awareness of quality, safety and the value of their parts, they have provided some cut away images. They regularly purchase and dissect competitor’s parts to make sure their designs are top notch. Below are the cut aways of their upper ball joint for a C Body and the current Moog part. Note that the pictured Moog design is the same thing they are currently seeing in other no name Chinese parts.
Here is the assembled cut away.
Original 5 megapixel image - 768kb
And disassembled.
Original 5 megapixel image - 723kb
At first glance, it might be hard to spot the superior design, it was for me. That was until the materials were explained. The top unit is the Just Suspension part and the lower is the Moog part. Here is a further breakdown of the parts.
Full resolution PDF - 471kb
Just Suspension has provided the following technical points:
1) JS fully machines the cases internally and externally, not just the wear surface. This makes for more precise fitment into the control arms (upper) or spindle (lower).
2) Only the wear surface of the JS part is heat-treated (the blue part), whereas other typical BJ's go the cheap route and heat treat the entire case. The benefit is that the non-heat treated areas (the control arm mounting areas) remain malleable and won't crack. This helps the ball joint stay in place, and keeps the arm from cracking.
3) The JS Ball-studs have twice the number of grease journals vs. the other, enabling more consistent lubrication.
4) JS uses spring steel pre-load springs & washers, whereas the other uses plastic. (these parts are the flat cupped metal washers on the JS part and the big black doughnut on the other). Further, JS has a machined ball stud seat (the part between the top of the ball stud and the flat cupped spring washers). These parts are the most important pieces in the ball joint. The spring steel spring-washers provide more durable and consistent pressure on the ball stud as the suspension travels. Also, the ball stud seat concentrates that pressure on the central rotating axis of the stud, reducing friction and making the travel of the stud more consistent throughout the range. The plastic doughnut covers the entire upper surface of the ball joint, increasing friction and actually resisting movement as pressure increases. It also wears out faster.
The net result is that the plastic tensioner will provide mushier & less precise handling and ride characteristics. That will require more steering inputs/changes, cause a more vague/wallowy ride, and slow slalom times due to slower suspension reactions. In essence, the JS design makes the car feel and perform more like a newer vehicle.
5) JS seals the case with an o-ring (making it water tight), whereas the other simply knurls the case closed (allowing water to seep in).
6) The JS grease zerk mounts directly to the ball stud seat (it pokes up through the larger opening in the case seal). The other simply has a hole in the case seal. This means the JS design allows grease to travel directly to the ball stud surface and then squishes around the case. The other has to squish around the rubber doughnut and through the center hole to finally arrive at the ball stud.
Go to www.cbodydrydock.com
The home page will have all the detail including the picures that did not make it here.
patrick
Post by patrick » Tue Oct 02, 2007 9:53 am
Wow, I didn't know there really REALLY was a difference! It seems everyone goes with P-S-T, either because it's cheaper or because it's trendy, and perhaps it's a little sheep mentality too. I know Firm Feel is doing wonders for the Mopar suspension cause, and I know of a few parts I will get from them no matter what, but I had no idea that the parts varied so much! I think I'll have to :beer: to Just Suspension and get my main kit from them.
100% Death Proof
JimF
Polygraphite
Post by JimF » Thu Oct 04, 2007 10:27 pm
I go with PST, and I've purchased 3 sets over the years. I've never had a bad experience and the one time I needed tech support they were very responsive. Just Suspension is also good, but the last time I bought parts there they completely screwed up my order and I had to return everything.
- Jim
