Post by 71Beeper » Sat Jul 25, 2020 3:33 pm
Today was the big day!!!!
Picked her up from the body shop.
July 25 (1).jpg (191.75 KiB) Viewed 28836 times
July 25 (3).jpg (190.59 KiB) Viewed 28836 times
July 25 (4).jpg (134.08 KiB) Viewed 28836 times
July 25 (5).jpg (171.99 KiB) Viewed 28836 times
July 25 (6).jpg (167.83 KiB) Viewed 28836 times
Post by 71Beeper » Sat Jul 25, 2020 3:35 pm
More pictures......I'm stoked!
July 25 (7).jpg (85.96 KiB) Viewed 28836 times
July 25 (8).jpg (128.1 KiB) Viewed 28836 times
July 25 (9).jpg (103.41 KiB) Viewed 28836 times
July 25 (12).jpg (116.85 KiB) Viewed 28836 times
July 25 (13).jpg (131.69 KiB) Viewed 28836 times
Post by 71Beeper » Sat Jul 25, 2020 3:56 pm
Can't forget my assistant.....
July 25 Susans pics (15).jpg (69.21 KiB) Viewed 28835 times
July 25 Susans pics (43).jpg (129.46 KiB) Viewed 28835 times
Post by 71440 gtx » Sun Jul 26, 2020 7:19 am
woooooow i :D :beer:
Post by 71Beeper » Mon Jul 27, 2020 6:23 am
Ever since I saw Bruce's RR on this site, I knew I had to go white with mine. :D
Post by 71Beeper » Sat Sep 05, 2020 5:31 pm
So the first order of business was to get some protection inside the wheel wells.
Instead of just going with the usual undercoating, I decided to use this stuff.
August 9 (4).jpg (135.39 KiB) Viewed 28630 times
August 9 (5).jpg (137.72 KiB) Viewed 28630 times
Being a truck bed liner, it is tint able, so I bought a quart of W3 enamel to mix into it.
The end result is fabulous! The stuff goes on like butter.
I had to use a smaller roller to apply because a Schutz gun can not spray upside down.
Here's the results....
August 9 (6).jpg (71.61 KiB) Viewed 28630 times
August 9 (13).jpg (67.88 KiB) Viewed 28630 times
August 9 (10).jpg (30.09 KiB) Viewed 28630 times
Post by 71Beeper » Sat Sep 05, 2020 5:33 pm
I also put her fender tag back on so she can have some identity.
Aug 20 (4).jpg (35.3 KiB) Viewed 28630 times
Post by 71Beeper » Sat Sep 05, 2020 5:46 pm
The next step is to get a cut & buff done on the clear coat.
The young guy I found to do it in my garage is great.
This is his daily driver... :shock:
Aug 27 (10).jpg (156.73 KiB) Viewed 28630 times
Here he is hard at work.
Aug 27 (5).jpg (107.21 KiB) Viewed 28630 times
Aug 27 (6).jpg (95.6 KiB) Viewed 28630 times
Aug 27 (7).jpg (93.27 KiB) Viewed 28630 times
He's coming over on Labour day Monday to finish it off.
Post by 71440 gtx » Sun Sep 06, 2020 2:47 pm
woooooooooooooooooooooow :beer: :D
Post by 71Beeper » Mon Sep 07, 2020 4:41 pm
Thanks Kevin - when are you coming down this way to help me assemble it?? :D
Post by 71440 gtx » Mon Sep 07, 2020 8:16 pm
i wold love to assemble it :beer: :D
Post by sdweatherman » Wed Sep 09, 2020 11:45 am
Holy cow man, I just spent 45 minutes going back through your entire thread on this car. Man you have put some time into this baby. But it just proves that anyone with a little ambition and time can do most of the work on a full blown restoration/resurrection and have a quality product in the end. I look forward to seeing the bits and pieces going back on the car now that the paint is done.
Post by 71Beeper » Thu Sep 10, 2020 8:26 pm
Scott, you certainly helped me by supplying the door that I needed :beer: .
Yes its been quite the journey for me. You and the others here can relate as we are doing what we can ourselves to try and save some $$$.
Yes I did fork out quite a bit of $$$ for the body and paint but if I gave it ago myself it certainly wouldn't have turned out the way it is now.
Anyway, once Ryan is done with the cut & buff I do need to touch up the area under the dutchman panel. Not enough paint on it.
I had some enamel paint spray bombs made up and will do that next.
After that it's on to the front end to black out the area behind the grille.
Post by 71Beeper » Sun Sep 13, 2020 3:14 pm
So the cut and polish is complete now. Ryan finished last night at midnight.
He put a final coat of wax on it. This is the stuff he used.
Sept 13 (2).jpg (89.29 KiB) Viewed 28575 times
The car certainly is shinier than before - and when it was painted it was shiny.
These indoor pics may not do it any justice.
Sept 13 (4).jpg (69.24 KiB) Viewed 28575 times
Sept 13 (7).jpg (66.39 KiB) Viewed 28575 times
Sept 13 (10).jpg (86.13 KiB) Viewed 28575 times
Sept 13 (11).jpg (87.09 KiB) Viewed 28575 times
Post by 71Beeper » Sun Sep 13, 2020 3:18 pm
I finally was able to get this mounted on the wall in the shop today.
Sept 13 (16).jpg (136.49 KiB) Viewed 28575 times
My wife bought it as a birthday present some time ago - but because the shop was a mess with the underside bead blasting I didn't want to hang it then.
I think it looks good in it's new home.
Sept 13 (13).jpg (98.03 KiB) Viewed 28575 times
Sept 13 (14).jpg (114.79 KiB) Viewed 28575 times
