Ash tray restoration
- Serious Satellite
Why did you get the penny out.... it might have come from the factory that way..!.!.!.!.!..Serious Satellite wrote:What about a brass brush? That and the naval jelly could get rid of that last spot.
My ashtray was so bad, it had a penny stuck on the bottom like someone used JB Weld on it. . .had to use a small chisel and ball peen to get it loose. . .
- Serious Satellite
RS23 '71 wrote:Why did you get the penny out.... it might have come from the factory that way..!.!.!.!.!..Serious Satellite wrote:What about a brass brush? That and the naval jelly could get rid of that last spot.
I needed the money. .
- fourforty6pac
Here's what I do. One gallon of distilled water, add 1/8 cup of laundry soda (not baking soda) mix well. You will need a low amp battery charger. attatch a piece of 1/8 in. steel about 12 in. long to the pos. clamp on the charger and the neg. clamp to the part you are removing the rust from. Put the part in the mixture. Put the steel in the mixture so it is not touching the part, keep it as far away as possible from the part. Turn on the charger on a 2 amp setting. Make sure the charger is set away from the container because the fumes could ignite, do this in a well ventilated area. Let the part sit in the solution for at least 12 hours maybe more depending on the size of the part and the amount of rust. I used this method quite a bit on smaller parts and it worked very well and did not damage any part. It is ideal for parts with plastic or rubber attached because 99% of the time it will not harm the rubber or plastic.
Before you do this try it out on a piece of rusty scrap and see how it works. I'm not home and I don't have my notes handy. It is possible that I have the pos. and neg. backwards. It is also possible to tweak the mixture a little by adding more soda to it.
do a search for electrolytic rust removal.
- Serious Satellite
- fourforty6pac
