removing the stripe ?
beep beep guy
My Cars: 1974 roadrunner clone
Post by beep beep guy » Wed Mar 30, 2011 11:27 pm
Ok I've hurd you can use a razor blade but idk about that cause one slip up gonna mess up paint and I don't wanna have to paint the entire car any suggestions
Mopar or no car! Beep beep
moparmike
Re: removing the stripe ?
Post by moparmike » Thu Mar 31, 2011 8:56 am
Do not use a razorblade...I think the best 2 ways to remove the stripe are as follows:
Heat Gun........Hold it near one end then try to get a fingernail under it.....gently start to pull the stripe back in a staright line (do not fold the stripe as it comes off. Once it is off then wash the area with a solvent to get the glue off by rubbing it in a circular pattern let it sit for a minute or 2 and the glue should become kinda gummy then wipe it of again in a circular pattern. Once the glue comes off with the solvent then wash the car to remove the solvent.
Or you can try using just a solvent it might disolve the glue enough to remove it cleanly.
Now remember I profess to only be a master of my own opinion so lets see if others in the nest agree or have alteratives measures.
beep beep guy
Post by beep beep guy » Fri Apr 01, 2011 6:23 am
ok sounds like i will be getting a heat gun reason im taking decal off its all cracked up it lasted 20 yrs not to bad and thank you mopar :D mike
SureGrip
Post by SureGrip » Fri Apr 01, 2011 7:38 pm
They also make a gummie rubber 'disk' that is designed to remover stripes and such without damaging paint. Sold at most auto-body supply stores.
droptop
My Cars: 71 Road Runner
Post by droptop » Fri Apr 01, 2011 10:43 pm
I have used one of these. Works just like a pencil eraser. The heat gun can damage the paint if you get it to hot. Plus, if the stripe is hard and cracked, you will never be able to peal it off. It will just come off in pieces.
Post by 471Magnum » Fri Apr 01, 2011 10:52 pm
If the stripe isn't too old, a heat gun applying moderate heat can help peal the stripe loose in large pieces.
If the vinyl on the stripe is old and brittle, a heat gun won't work very well, but the eraser will. The erasers are primarily intended for pin strips though. Doing a large stripe will probably be very tedious.
beep beep guy
Post by beep beep guy » Sat Apr 02, 2011 7:02 pm
yeah its old cracked up all over so ill get the eraser might take me awhile to get off but im gonna wait till i get new stickers thanks allot guys :D
Post by rr6pak » Tue Apr 05, 2011 10:41 am
Is the stripe bad or what? Just want to remove it? Or you could just leave it. I know I'd be toooo nervous to try and remove it for the sake of having to replace it
beep beep guy
Post by beep beep guy » Tue Apr 05, 2011 3:22 pm
it needs replaced but not gonna take it off till i get new stripe
